Discuss How Much SLC do you think I need in the Canada Tile Advice area at TilersForums.com.
Filip
498
Midlands
I have an outside area to level up and think I will be using Mapei P4, the area is 2.8 long x 1.3 wide and the lowest side is 18mm too low along the 2.8 length rising to a feather at the 1.3 wide mark. How many bags do you think I will need please.
Filip
498
Midlands
I have just double checked with my local tilemaster supplier and ther is no problem with bringing back whole bags, so I think I will start with two
Q
Qwerty
Can you please let me know who allows you to take back part used bags, I could make a fortune on my 1/4 bags I have on jobs :D
Filip
498
Midlands
Ok I am reporting back with my findings after doing the job.
3 bags were not enough and that stuff is a nightmare to get off your tools, even a trug bucket wont help because the SLC is flexible just spent about 2 hours cleaning the tools and guides. Next time if I nned to go so deep I will be going old school with a skim of cement and wait 1 mm per day which would be 1/6th of the cost in SLC.
So after all the prep work and expense I still need to bring the level up with thicker addy.
AND an end stop I made leaked and I have a lovely pool of SLC - self levelling itself all over my a joining slabs. Sand and cement don't do that !
Sand and cement needs to be pretty thick or it has no strength.
That's why slc was invented!
Use PU foam in a can to make an easy, effective dam that you can cut away afterwards.
Filip
498
Midlands
Hmm maybe sand and cement for the thicker deeper bits and the SLC from then to the feather. I did notice when cleaning lots of cotton wool type filaments. I think you can get that for normal cement.
Because I messed around with it I had some areas that I needed to take down which are now a bit rough I am thinking of re priming - wouldn't hurt would it ?
Chris N
268
Nuneaton
Now you've got the trough filled, why don't you re-level the whole area with SLC and have a nice flat surface to start from?
Filip
498
Midlands
I still have another 10 mm -feather to go and I spat my dummy out over paying £60 for 3 bags and its still not level I am thinking of building that part up with extra addy today but that is £15 a bag so wont be saving much.
Can I add SLC to a floor with it already on and do I need to re prime.
I was told that the SLC is of for my outdoor use as it fits the requirements but to be honest it is nigling at the back of my mind that it is not a "full blown" exterior SLC but the Addy is.
Here is my post about that one
Reply to How Much SLC do you think I need in the Canada Tile Advice area at TilersForums.com
