Help please repairing floor
I have a large kitchen 65m2 laid by builders on a suspended floor.
builders used, 18mm Ply and ditra matting and the laid 600x600 tiles. Floor is 4 years old and I have lots of movement, 50+ cracked tiles and grout falling out daily.
I don’t know what to do anymore - builders are now uncontactable and I’m considering small claims court.
what did they get wrong and what should I replace with ? Floor cost £8k+
Builder actually subcontracted to tiller
yes 18mm direct onto joist and porcelain tiles used.
I have one 2nd opinion so far stating that backing board should have been used.
thanks in advance
18mm ply and ditra is perfectly acceptable, but there is a lot that can go wrong if not done properly.
Could be insufficient noggings , ply not primed , tiles not bedded properly and the list goes on...
Is there lots of bounce in the floor could be numerous reasons but might be a floating floor
[automerge]1578608404[/automerge]
Do you know what’s under the ply
Is there a scientific way of measuring bounce? Is it true that Ditra only helps with lateral movement?
[automerge]1578636664[/automerge]
Not really - the joists and underfloor heating
Get a glass full to the top with water, sit it on the floor and jump up and down. 🙂
Or piped within the joists ??
Thats what I reckon pipe work in between the joists all sitting on top of insulation I looked at a big floor the other day and it was the same they are having wooden flooring instead of tiles now as I advised
Sorry for not being clear - I’m a novice
bottom up Joist, with celotex between and then aluminium trays with pipes for UFH then ply, then ditra and finally tile. The floor is one big kitchen dinner and is approx 65m2. There is also brick support in the floor for joist etc. Thanks everyone for your help.
So what you described should not fail if done properly . Ply should be fixed securely and all joints supported. So either falling on a joist or a noggin.
Ditra should be stuck securely with coverage completely under the matting, then when installing the tiles all mat cavities should be filled prior to creating a rib bed on top and then tiles should be back skimmed and fixed to ensure full coverage but all of that is no good if you can feel the floor moving prior to tiling .
You need to see if the tiles are stuck to the adhesive.
From what you said it is either fixer error or thermal shock imho
What expansion /movement joints are in the floor?
I take it the ply was fixed correctly, backs and edges sealed and 5mm gaps between boards filled with silicon
Storrs,
J Sid,
Storrs,
J Sid,
