Discuss Help please repairing floor in the Canada area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
Storrs
I have a large kitchen 65m2 laid by builders on a suspended floor.
builders used, 18mm Ply and ditra matting and the laid 600x600 tiles. Floor is 4 years old and I have lots of movement, 50+ cracked tiles and grout falling out daily.
I don’t know what to do anymore - builders are now uncontactable and I’m considering small claims court.
what did they get wrong and what should I replace with ? Floor cost £8k+
Storrs
Builder actually subcontracted to tiller
yes 18mm direct onto joist and porcelain tiles used.
I have one 2nd opinion so far stating that backing board should have been used.
thanks in advance
ttt tiling
18mm ply and ditra is perfectly acceptable, but there is a lot that can go wrong if not done properly.
Could be insufficient noggings , ply not primed , tiles not bedded properly and the list goes on...
Joshjupp
Is there lots of bounce in the floor could be numerous reasons but might be a floating floor
[automerge]1578608404[/automerge]
Do you know what’s under the ply
Storrs
Is there a scientific way of measuring bounce? Is it true that Ditra only helps with lateral movement?
[automerge]1578636664[/automerge]
Not really - the joists and underfloor heating
Boggs
Get a glass full to the top with water, sit it on the floor and jump up and down. :)
Reply to Help please repairing floor in the Canada area at TilersForums.com
laattaana
