Grouting nightmare - help pleaseee
C
Crumbs
Hi guys, having a nightmare grouting a bathroom to a white colour.
I started with mapei ultracolor white, alot of it came out light grey and i ended up degrouting the lot as was not pleased with the colour against white tiles.
Now armed with grout 3000 in pure white, i done a very small section and again its come out light grey. Heres how i do it.
- Mixed with paddle and by hand, left to stand for 5 mins then re mixed to a paste.
- Applied with a float and removed excess with the float
- Waited 20 mins then sponged down. (2 buckets and wrung all water out of the sponge) lightly washed down.
- Used a plastic pipe to tool the joints after sponging down
- Left to dry
The remaining mix not applied has dried and is a pure white colour as expected so not the mix? Its been around 36 hours since its gone on.
According to the bag it will cure in 24 hours but it is on a waterproof membrane so is it possible it may take longer to dry out? what i did notice was when i done my first grout attempt with the mapei uc, the area above the sink did actually dry white and this is the only area that was not tanked so i am thinking that i did not give the grout long enough to dry?
Any help is appreciated guys as i am at a loss and tired of trying to get it to come out white, what am i doing wrong?? 🙁🙁 thx
Tiles are ceramic. I get that but the bag says 24 hours and after 36 hrs still looking light grey 🙁
Wondering if tanking behind the grout slows the cure? Does my method of application look good to you? Thanks bud
I find with most grouts that they can take 3-4 days to fully dry and become water resistant.
It's often difficult to convince a customer that it will dry a lighter colour but it does.
I try,
If the ceramic has some glazed edges
and some unglazed,
The grouting, dries faster, where there is no enamel.
And more slowly where it is .
Usually when it dries fast, it remains beautiful white.
The color difference could be created by this factor.
which is very visible in the colored grouts.
It's just a matter of drying.
I hope you understand.
This is one reason I dislike using Gloss white tiles ......
The tiles are white.
The trims are a different shade of white,
The grout is a different shade of white,
So everything is being compared to the brightest shade of white,which not the the grout.
Thanks guys...days passed and nothing changed, de grouted the small area. Regrouted a new test areas... and come out grey again. Did 4 areas, 2 on tanking membrane with a sponge washdown and one without (just tiles cleaned and joints tooled) and 2 on area above sink with no tanking with and without washdown.
All 4 come out light grey / ivory ish. I know its going to show up more against white but its no where near "pure white". Sanding a little of the top reveals white lines, really confused to whats doing it now. Considering remaining paste is bright white and no wash down to remove the possibility of excess water. Only thing maybe causing it is using a plastic pipe that breaks up the grout lines weaking/damanging the grout.
Think i will try to source bal micromax 2 snow grout, meant to be a brillant white. Anyone know where i can buy it from - no where seems to stock it. 😡😡
The sponge ones with the rubber face can become stained with coloured grout. I only use solid ones now and still keep a separate one for white.
Never used on anything but white grout bud, going to try some different finshes (sponge, finger, plastic pipe) only thing left i can think is causing it. Other than that will swap out for MM2 snow
The snow is a difficult colour to get at the moment. Its fairly new and will take a little while to filter through to all the suppliers.
Before ripping it out and starting the test again, you could try epoxy or a grout colourant such as Mapei Fuga Fresca or Universeal Grout rescue. At least that way you'll have a back up option to try if you never get the brilliant white you are after.
Do you have any pictures of the existing grout so we can see how bad it is?
places can order it in but it aint cheap stuff - struggling to find many alternatives. £35-£40 for a 5kg bag vs £13 for grout 3000 / mapei UC 🙁
Would of thought majority of grouts that were white, were as such - white. Pic attached bit rubbish quality sorry. Makes the joints look dirty and not fresh.
Another area i sanded down a little bit and the white to that is pretty much bang on, but i cant go around every joint and sand, esp as it marks tiles.
The colourant is a last resort really, rather not use that if i can help it - prefer the grout to be right in the first place. Any other brillant white grouts anyone can recommend?
If you were installing white glossy tiles with white grout, is it expected for grout to be off white? thanks bud
Not sure you being too picky as getting grout to a perfect 255,255,255 (colour spectrum) would be nigh on impossible especially when you factor in the lighting conditions plus the shade variants against white tiles - gawd knows how many whites I have seen over the years.
Anyhoo, I have magically adjusted your photo for correct white balance to help show the peeps the true colour under daylight conditions. When I checked the grouts against the tiles, the colour score of the bottom one was almost identical to the tile, around 179,179,179 so even that shows that your tile is not pure white, will you take the tile back because it is not pure 255,255,255?
I doubt the tile is pureeee white but the grout certainly is not. We're looking at this through computer images so its hard to gauge it tho it defo is not white, i dont want it perfect but it does look grey. I guess this is why BAL relaunch there shade of white to be even whiter as its likely like the ones ive been using.
Think ill try unibond you recommended, i always thought they were a bit rubbish and frowned upon? Reviews look good apart from 1 guy on amazon say "after 6 months turned yellow and crumbly" so thats a bit worrying!
Crumbs,
Time's Ran Out,
Crumbs,
Time's Ran Out,
