Discuss Grout cracking at tile edge in the UK Tiling Forum area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
Pierluc
Hey there, i just finished the tiles in my house and i am having this problem in a couple places. this is the section that my grout was a little too wet but i used it anyway could it be the problem ?
i used Chembond adhesive and mapei ultracolor plus grout, sub floor is 3/4 inch OSB 3/8 ply, screw at 3 inches square, 3/8 thick tiles, 3/16 spacing
there is no movement on the floor, im really wondering if too wet grout and not pushing it in enough is the problem. this is the only section where i failed the mix the other parts are fine
thx for the help
Pierluc
between tiles laid on the floor, it seems like the grout did not stick to the side of the tiles at some place, as if it would have shrink
doug boardley
with mapei ultracolour, you have to follow the instructions to the letter, it's a formidable grout when mixed properly. I think it probably is the reason, although your ply should also have been at least 1/2 inch.
Pierluc
3/8 ply is all we use in Quebec and i never had problem this way, but yes maybe i could have taken thicker one :smilewinkgrin: theres another 1/8 sheet between my 3/4 and the 3/8, the stuff they use to put linoleum on, should i have remove this piece ?
DHTiling
Have you done a deflecto test on the joists....
Your sub-base should be fine.... what Standard is the thinset..? is is modified in anyway.
Pierluc
High-Performance, Polymer-Modified Floor and Wall Tile Mortar
MagniFlex Ultimate 8830 is a high-performance, polymer-modified, single-component, thin-set mortar for setting ceramic tile and dimension stone
Deflecto :
For joists that are SYP or Douglas Fir, in good condition, 9.25 inches tall, 1.5 inches wide, 16 inches on center, and 14 feet long between supports, the deflection calculated is 0.442 inches.
This translates to a deflection of L / 380.
Since the maximum deflection for tile is L / 360, and for natural stone is L / 720, your floor is rated for Ceramic tile, Congratulations!
Seems like im just a hair good enough for ceramic tile, would adding more wood cross under the floor help ? or another hanging beam halfway to distribute the weight ?
but i dont thing structure is the problem, the half section i did with the grout mixed well did not crack at all .... or not yet
DHTiling
OK all is well...
I think you need to remove the bad area's of grout and re-do them..:thumbsup:
Pierluc
hard to see, had to wet the floor to see it, its just a couple weeks old i hope it doesnt get too bad. Any electric tool working well to remove grout ?
Reply to Grout cracking at tile edge in the UK Tiling Forum area at TilersForums.com
Apatel
