B and Q rapid set adhesive
U
Unregistered
Hi I am tiling over a woden floor with plywood down first. I have seen a adhesive for a very good price at B & Q £8.99 per 25 kg bag. The problem is it says not suitable for wooden floor. Is this because it as no adative mixed in? Meaning if I add an adative it will be OK.
Are all rapid set adhesives without adative not suitable for wood floors? I.e once adative is added it amkes it suitable.
I have done this in the past but cant remember if the adhesive I used specifically stated not for wood floor. I know alot of companies just try and make you buy the expensive pre-made stuff.
Thank you
Tony
Avoid this adhesive at all costs Tony....what thickness of plwood have you laid ? is it onto chipboard or T&G boards......Gaz
It's obviously just rapid set, as opposed to Flexi rapid set. You could add a latex additive to make it flexible but I would avoid all B&Q adhesives, go to a reputable tile store, try and stick to astablished trade adhesives eg, BAL, Palace Chemicals, Granfix etc. Thats trhe best advice I can give you.
Hi
Thank you for your replies. I understand where you are coming from but I have used this adhesive in the past, but in a kitchen on a cocrete floor. It did have a good consistancy and have not had any problems with it coming up yet (layed one year ago).
I am laying on to P5 chipboard and the 6mm Plywood screwd down at 300mm centres.
The main reason for my post was as the bag does not recomend this for wood is this just because it does not have the adative in. Meaning if I ad the admix it would make it suitable for wood?
For example I am a car painter by trade and we can not paint over soft rubber without a flexible adative but once adding this the paint is suitable to paint soft rubber.
Cheers
Tony
Hi
Tony you need to screw the chipboard to the joists first then fix at least 12mm ply
better still use 10 tile backer board put down with fastflex timberflex ect 😛ete
Hi have as they are the floor boards which I fitted to the whole of the new floor. In My old house this is what I did over tounge and groove boarding and never had a problem in 8 years. Are you sure as I have read that its 6mm over the chipboard flooring. I dont want to make the bathroom floor to high so I get a nice join from tile to carpet wood etc.
the thiner the substrant the more chance of movement.
id be more worried about move ment than thickness of finshed floor.
benfer fix sell a liquid to mix with there standard rapdid set,
dont think ive used better than bal fast flex..
sometimes you can tile straight onto the floorboards if you haven't any deflection are you sure of what deflection you have or are you going to take the risk ? also 6mm ply unless its stuck to the floor will have a certain amount de-lamination affect not the best way to put it :lol:
Unregistered,
Perry,
Unregistered,
Perry,
