Discuss Is my tiling acceptable? in the Canada Tile Advice area at TilersForums.com.
36
Wrexham
Hi.... I have recently had my bathroom refitted and tiled floor to ceiling. The company tell me the tile does not cut cleanly and they have now covered the chips around the window with a stick on trim which does cover the mess, but should I accept this? The tiles used are Nest white glazed ceramic by Love, we have not been able to take a tile to someone else to see how they cut as the tiler took all our spare tiles with him! Also we have a small gap around the door frame that they said was too narrow to tile so nailed a piece of wood in the gap and said when painted the same colour as the door frame it will look fine, is this acceptable or should they have removed the door architrave? Also the boxing in of the pipes is rough and one of the pipes is not covered. See pictures. Many thanks for advice regarding these issues. Jayne
J Sid
Very poor and you shouldn't pay until its been sort
Really can't believe it was a professional tiler which the standard of workmanship.
Trim work is shocking and the chipping would have been a easy fix.
36
Wrexham
Thank you for your much appreciated and quick response. We are have a nightmare with them, when we tell them we have asked for second opinions, they just question the other companies knowledge on tiling, that’s why I thought I’d try and get expert advice on this forum.
Boggs
1,118
Uk
That’s quite an inventive piece of trim work right there. 😂
All round poor job. :(
That is rough . Yes those tiles arent the best cutting but a tiler with a small amount of skill , experience and would produce better cuts than those ,
Maybe you could ask them what their knowledge of tiling is and ask them wether their tiler holds an nvq or city guilds in tiling , I know many on here don't so don't have a go , but I am just throwing the ball back at them with their dismissive comment .
Sean Kelly
1,068
Ruislip
Jayne,
Do you have 2 windows in your bathroom? Or is that the stick on trim on the 6th picture?
I have never heard of ‘stick on trim’.
The trim around the boxed in section is appalling. This need to be redone. It would have been better to box the pipe in and have a removable panel.
I would not have removed the architrave around your door, but I would have tiled ‘slithers’ of tile (even if it had taken me an hour to cut them).
If the person doing the tiling could not cut a tile with an acceptable finish then he should have stopped and informed you.
If you had purchased the tiles they belong to you the company has no right removing the spares (if there were any left over).
Your grout colour has highlighted all the dodgy cuts in your tiles. The grout colour could be lightened by the use of a grout colourant (Universeal grout rescue). Have a look on ebay.
36
Wrexham
Jayne,
[automerge]1579969102[/automerge]
Yes the 6th picture is the stick on trip. Thank you for your advice, they were starting to make me think it’s me being picky
[automerge]1579970311[/automerge]
36
Wrexham
Not good job mate don’t pay till you are happy with the job
They have unfortunately had £6000 off us, as they were doing our main bathroom and clock room, but we have not let them do the clock room following the problems with the bathroom. We just don’t know where to go with this, they make me feel I’m looking for problems 😔
[automerge]1579975078[/automerge]
I’ll ask them, thank you. Worth a try
Reply to Is my tiling acceptable? in the Canada Tile Advice area at TilersForums.com
