Discuss epoxy resin over old tiles in shower room floor?? in the Tanking and Wetrooms Forum area at TilersForums.com.
pcm77
hi guys. i . have a showroom floor to put some epoxy on thats currently tiled..old orange quarry looking tiles.im hoping some 1 can point me in the right direction regarding getting the epoxy to bond to the tiles..apparently tiles are a pain in the bum to lay this on to...some 1 advised this
self levelling compound Tilemaster Adhesives LevelFlex – 20Kg
is there an easier way to get this to adhere like a primer mayb
thanks in advance for any tips
I did here once epoxy needed a special levelling compound , I think you need to speak to your epoxy supplier as for normal levelling to tiles tilemaster prime and grip but you have to be sure your existing tiles are well bonded
Dan
Admin
Try get the odd one up in the odd area. If cars have been over them quite a lot test near large doorways etc. If you do manage to get a tile up but it was hard work, stick it back down with cement based adhesive the day you start setting out.
Should find wobbly ones if anything at all maybe.
If it's all fine then acrylic primer before levelling and then primer again before tiling and then epoxy for grouting only maybe?
We are we using it to tile with did I miss that bit?
(I'm not a tiler I'm here to play with your mind)
Wayne Brown
Dan there more to it than that mate the op wants to bond a epoxy resin floor to existing quarry tiles , you keep pushing them buttons ;);) I would say contact the resin flooring manufacturer for guidance. Kop
pcm77
yes thats kinda where im at with it... the suppliers guy said to use
the level flex . compound,,i was just hoping there wouldve been an easier way...
dont want to take a chance of just putting it down for it to fail in 6 months.. cheers lads
Dan
Admin
Ahhhh I was miles out lol. Think I need a new phone too that typing is terrible.
Wayne Brown
There is a clip on you tube showing floor prep over quarry tile for a expoxy resin floor . Kop
pcm77
you sir are a legend..exactly what im looking for
my original post i stated the tiles were old quarry i think i was wrong do you know what these are from this really bad photo?
that primer hes using looks the part many thanks
Wayne Brown
Cant really say bud I would say that as long as they are sound and well fixed the job is possible, I used to do alot of work in school kitchens they would have a specialist firm lay the epoxy resin floor often it was over tiled floors best of luck . Kop
pcm77
cheers mate.ive placed my order this morning battle plan is grind the tiles prime them then ,self leveling compound,prime again, epoxy coating then a top coat...great video . you linked me 2...watched quite a few on there after as you said as long as there sound itll take...lets hope i dont mess to many tiles up sanding them off
Wayne Brown
Sure it will go well stick a good price in though;)
pcm77
lol i have mate room on the price for a suprise or 2..
aprreciate your help,,,is frustrating when people want to spend so much money for a quality floor and try pennie pinch over taking some tiles up.
Reply to epoxy resin over old tiles in shower room floor?? in the Tanking and Wetrooms Forum area at TilersForums.com
  • Poll
Teejay
