Discuss Preparation of bitumin floor in the Canada area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
jafeica
im going to tile over a solid floor which has a thick layer of bitchumin over concrete. House probably built in the fifties. Tiles are porcelain my question is - What is the best method to prime or prepare the surface for tiling. Will be using topps own standard set addy
Q
Qwerty
Remove any large deposits with a scraper and then prime with a SBR/ cement slurry or use a grit primer (prime & grip or eco prim grip)
Any pics?
Are you sure it is bitumen .
I've worked in ex council houses that had a red resin type floor down , I'm sure someone on here will know what that was, I can't remember the name ,
Ajax123
At 20mm built in the 50s be careful as it could be magnesite. These were often red, green or black and they will not take a tile adhesive or slurry. A quick easy test would be to use an electric damp meter like the ones used for testing rising damp. If its magnesite the moisture reading will be very high or off the scale
On one
Is the colour of the floor black black(bitumin) or a deep burgundy (black pudding) colour?
I used to live in a 50's house, where the whole ground floor was supposedly levelled with a 20mm burgundy coloured coating, matt in colour.
That’s called ‘Magnasite’ and is a banned substance now.
It soaks up water like a sponge.
They also used to use all manner of fillers in the product.
The most dangerous of all was asbestos.
It should be removed before work commences.
Just Rizzle
try reading up on BAL FLEX BONE if the floor is flat and smooth just lay over and tile
Ajax123
Haha I’ve just seen Alan’s post :)
Twice is better than none at all... at least that's what my Mrs says... magnesite was dreadful stuff though. Still an awful lot of it out there. It was mainly used in council houses....
Ajax123
That's a good point Ray. Would be interesting to see if they would recomend it over magnesite. Cant see why not...
Reply to Preparation of bitumin floor in the Canada area at TilersForums.com
Lowpaul22
