Discuss What filler to fix hole in plaster board? in the DIY Tiling Forum area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
Romelee
Hi all,
I have a wall that has two layers of plaster board, the wall is in good condition apart from one thing, there is a hole about 4 inches wide by 3 inches high and about 15mm deep, i really don't want to rip down a whole wall due to one hole, can it be filled ready for the wall to be tiled?
If it can be filled is there anything on B&Q that can be used as it's only around the corner from me and i don't drive.
All the best
Jay
Waluigi
Cut a slightly larger rectangle out. Gripfill a new piece of board in and then easi-fill over it. Sand once dry.
Alternative method would be to fill with bonding plaster, a little bit of dust added to the mix (cement) to help it set faster. When almost set, scrape it back a little so it’s slightly concave and fill and feather the edges with easi-fill.
Albert
Hi all,
All the best
Jay
Just square it off and stick a new piece of plasterboard in.
On one
Unless your using small tiles or mosaics to tile the wall,a hole that size wouldn't be of much concern.
Waluigi
Oh it’s getting tiled. I assumed it was a random DIY question. I didn’t read the tiling bit :tearsofjoy:
widler
I take it its a solid wall not a partition? If its solid just fill it with your tile adhesive, as long as it a bagged .
If its a partition,cut the hole swuare cut a piece of 2x1 a inch or 3 bigger than the hole, place it inside , and screw through the front of the plasterboard into the wood, then plasterboard the hole
Reply to What filler to fix hole in plaster board? in the DIY Tiling Forum area at TilersForums.com
Northern Tiler
