WetSaw
I'd use a multitool to clean out the grout then gently pop the tiles with a chisel/screwdriver. Then clean up the adhesive with the multitool.
I wouldnt want that cowboy back, I'd demand a refund plus costs!
If your happy that you have tanked it properly yourself with the fact that you've used a system from a manufacturer that can be regarded as one of the most advanced out there then you should have no problem removing the poor cuts around the grate. My confidence in this comes from the fact that the tiling is so poor that I doubt the tiles in situ have been well fixed.
I've been watching this thread from the start, and whilst Mark's (impish) comments about you being stressed had some foundation, you are now beginning to push your welcome here.
This is an excellent forum with excellent advice, I urge you not to be aggressive in the manner that you post.
There is absolutely no need for it, we all have opinions, and they may well differ from yours.
As the Americans might say, "get over yourself!" We're trying to help, we see this everyday of the week, whether it be here or on the job, and we DO know what we're talking about.
After all, that's why you're here isn't it?
So I'm sorry if you don't like all the opinions directed at your problem, take the ones you like, and suck the rest up!
Admin.
Then you need to re back the posts, I am one of several that has seen aggression in your manner.
So my post is hardly baseless.
But the question you ask is impossible to answer, if you as educated as you appear to be, then you know that removing the tiles without damaging the waterproof membrane you installed is exactly 50/50 yet you're searching for a definitive answer.
It doesn't exist, only conjecture.
And we have to assume that you installed it correctly.
If forums give you hump so much because it takes TWELVE posts to get an answer, firstly you must have visited a LOT of forums to come to that conclusion, and secondly why come back!
That's rhetorical!
And yes, your manner is aggressive as far as we are concerned, but that's subjective I suppose.
If he refuses to put it right then threaten to take him to the small claims court to regain your losses..
Assuming Sam the man down the pub didn't do it for cash..
Can it be fixed? How?
My question is CAN IT BE FIXED?
I did the waterproofing so I know it exists. That isn't the question.
THE TILES SURROUNDING THE DRAIN NEED TO BE REMOVED. CAN THIS BE DONE WITHOUT DAMAGING THE TRAY? HOW?
SO CAN IT BE FIXED WITHOUT DAMAGING THE SHOWER TRAY? How?
Excellent thread, not the most complex of threads, but an enjoyable one to read, by the way, I don't get out much.
After re-reading many of the posts I think I understand the question.
We're wanting a definite answer, non of this advise lark, a simple Yes, or No.
A yes or no, based on a total stranger being able to do a slow and steady tile removal, bash, chisel, scrape all adhesive away, type of job. Then obviously re-fit correctly with absolutely zero damage.
My answer is:
No.
Thanks.
I never work for cash . Perhaps you could threaten him with the tax man . I'm sure he would love an in investigation.No. It wasn't "Sam the man" but I've never met a tiler who works for anything other than cash.
At this juncture I am being realistic. Ask him to put it right and take it from there. Personally, I don't think I see how it can be fixed now without removing the full floor. What annoys me the most is that the one reason I didn't do this job myself is because a wet room needs to be done right and I was scared of making an expensive mistake. While the tiling may not be perect, I can live with it. I know the tanking underneath IS perfect. But he, who has done 80 wet rooms, and had used these exact tiles before, made a mistake at the single most important and crucial part of the job....and it's now causing me sleepless nights.
I've tried gently prying up the tiles; there is no movement. I'm worried about cracking the plastic drain or citing through the wet board. And if he does come and fix it I won't know for a long time if that joint it still waterproof.
My plan is, assuming he agrees to come back; inspect the tray closely after he has removed the tiles and make a judgement call.
Personally I don't think small claims court is an option. It only leads to more loses and frustration with no guarantees odd a favorable outcome.
there might be a "trick of the trade" to get the tile up and fix the job without a complete removal.
I dont think it should be too far fetched to come to a tiling forum to look for that sort of advice?
Looking at the standard of the install you have still never met a tiler.....
With respect, the install is not and has not been done by a professional in any way. You employed someone that only works for cash, which by itself is not illegal but in this industry sometimes suggests cowboy. Looking at your job it's leaning towards the latter.
Your right the payment method isn't relevant so why did you first bring it up? Why did you say you have never met a tiler that doesn't just work for cash?
You seem to be another person coming on here just to provoke people when you don't get to hear exactly what you want to hear. Collectively you will not find more knowledge about tiling anywhere else, yet you don't seem to want to hear any of it.
Legally you do have to give this guy the chance to rectify what he has done. But would you want to? you say there isn't anything wrong with the rest of the install, but there is...... it's not good tiling at all. He isn't a tiler.
1.All cuts around the drain prove lack of experienceYou say it is not a professional job. Please explain?
I would check the box this drain came in, should be a height adjustment kitThanks. Says he will come back this week and will fix it. Says is time consuming but not difficult.
You are right that it seems to be such a basic mistake. I'm even annoyed at myself for not realising this before the tiles went down. ...but I am not a tiler. I consists having a go but thought better of it in case I screwed it up.
There is another issue. At the moment I can't tell if the frame of the drain is the same height as the tiles. ...again as a professional this should have been a basic check.
But as you point out. ...I have nothing to lose by letting him try.
Thanks.
I get paid in cash 50% of the time and still declare the jobs it's a pretty silly thing to say only cowboys take cash lolWith respect, the install is not and has not been done by a professional in any way. You employed someone that only works for cash, which by itself is not illegal but in this industry sometimes suggests cowboy. Looking at your job it's leaning towards the latter.
