stephenoneill
quick from people who have used either one laying some large tiles in the next week or so
I was given them to try. They are not strong enough to lift large format tiles up to the level. maybe good for 300x300 but if you cant manually level 300x300 then you wanna give up !
Used lash clips a couple of weeks ago on approx. 20m2 of 600 X 600 tiles. First time ever and I was very impressed (did make my sensitive little thumbs a bit sore though squeezing the wedges in)
I have used LASH clips before which were ok to use. Turn the wedges around to save your thumbs :thumbsup:
Somebody mentioned that way at rays geoff. I dont use them but might try them on a job I got coming up.
Ramondi here, and i have been sent an american system and tool free of charge and the quality is fantastic........
Thought it was a thread on slc not tile levellers and then read other comments and realised lol
I have the riamondi too. Good but has limitations. If using rapid set, the spacer will set in the adhesive, then can only push down with the wedge. They are strong too, unlike the lash clips from tops, which you will need a metre deep bed to accomadation the curled up ends. I have only used hem on marble floors where you can justify them ( nearly).
still nothing better than a straight edge, a flat for checking lippage, a good toutch and a pair of eyes!
Rubi are excellent! Work for me anyway!
I've never used lash clips, all seems wrong to me, to create a solid bed you need to be pressing, not pulling....
I attempted to use lash clips the other day, but couldn't get my head around the amount of space they seemed to need under the tile, due to the curve!?! Gave up, and used spacers. I know where I am with spacers! Lol
raimondi use from 2011 , rls latest model is more flexible and better than old model
google translated
the eu rules are clear, over 60 cm in length should be made the double-spread, more bottom floor, so there are voids pronlemi . Google traslate
I use original Tuscan. It's the best. The traps might be expensive, and if you want something cheaper and faster godt with Leveltec, easy and fast going 🙂
I've just invested in a load of rubi and to be honest I'm a little less than impressed. With the lash clips you can actually pull the lip page out to a certain extent, the rubi ones you can't put much pressure on at all. They're more of an aid to hold your tiles in place once you've got them right in the first place. After buying the rubi system I'll be more careful about which system I buy next. Having said that though you still have piece of mind that once set they're not going to move.
best tile levelling system rubi or raimondi need to know
Best Tile Suppliers | Tile Supplier Discount Codes
stephenoneill,
Old Mod,
stephenoneill,
Old Mod,
