Discuss best tile levelling system rubi or raimondi need to know in the Tile Retail | Wholesale | Import / Export Tile area at TilersForums.com.
stephenoneill
quick from people who have used either one laying some large tiles in the next week or so
cam_low
1,048
South Woodford
I was given them to try. They are not strong enough to lift large format tiles up to the level. maybe good for 300x300 but if you cant manually level 300x300 then you wanna give up !
398
Used lash clips a couple of weeks ago on approx. 20m2 of 600 X 600 tiles. First time ever and I was very impressed (did make my sensitive little thumbs a bit sore though squeezing the wedges in)
Q
Qwerty
I have used LASH clips before which were ok to use. Turn the wedges around to save your thumbs :thumbsup:
Sean SML Tiling
Somebody mentioned that way at rays geoff. I dont use them but might try them on a job I got coming up.
Mr Tiler
That post is completely irrelevant to this thread haha..... what size are the tiles mate?
Mr Tiler
Thought it was a thread on slc not tile levellers and then read other comments and realised lol
Chalker
1,058
Tadcaster
I have the riamondi too. Good but has limitations. If using rapid set, the spacer will set in the adhesive, then can only push down with the wedge. They are strong too, unlike the lash clips from tops, which you will need a metre deep bed to accomadation the curled up ends. I have only used hem on marble floors where you can justify them ( nearly).
still nothing better than a straight edge, a flat for checking lippage, a good toutch and a pair of eyes!
Reply to best tile levelling system rubi or raimondi need to know in the Tile Retail | Wholesale | Import / Export Tile area at TilersForums.com
  • Poll
