Thermal Boards For Tiling Around A Bath and Shower
Good evening all. :thumbsup:
My next project involves tiling around a bath with a shower within a 7 year old apartment. When removing the previous tiles and walls i found hardibacker board at the shower end of the bath and double skin plasterboard on metal studs at the other ends.
My initial plan was to use 12mm hardibacker boards throughout because i'm installing large format tiles, however i'm having second thoughts becuase of the lack of thermal properties of this board. Is a thermal backerboard such as Marmox thhe only way forward £££, or would fitting i fit 1 x layer of plasterboard and overlay with hardibacker a better way to go?
Alternative sugestions much welcomed as usual.
Cheers
AJ
I would use 12.5 mm Marmox with taped joints and fixed with screws and Marmox washers.
Created on iPhone.....
Ok.. i hve gone ahead and fitted 12.5mm Marmox boards to the walls arround the bath and on the recomendation of Marmox, ran a bead of sillicon sealant between the boards before butting up.
What should be done with the joints? Should i use a scrim tape to support the joints or do i need to use a waterproof type tape for sealing the joint?
are you tanking the walls? all the joints and internal corners should be taped, and overlap the tape onto the bath about 6mm
there's different makes of kit available from the big tile shops, bal mapei etc. and theyre usually quite easy to do, if you do a search here or youtube you'll probably find a video on it
The Marmox are waterproof so the joints would only need tanking..
The Marmox waterproof tape is very exspensive for what it is .... Is their any alternatives out there?
Do i need to tape all the screwfixings also?
Do i use scrim joint tape to reinforce the joints prior to fitting the waterproof tape?
hi action,i know it seems expensive however without the tape your boards are no longer a waterproof installation and pretty pointless buying thenm in the 1st instance
is it just over a bath you are doing? if so you shouldnt need too much tape
you may be able to use an other make but would have no come back if it failed as it is not advised for that product
Hi Kilty, thanks for your help. Yes its a shower area over the bath so a 10m roll should do it!
actionjackson,
actionjackson,
actionjackson,
actionjackson,
