White Room
What is the sub structure?
What has got to do with it ?
Discuss White Floor Grout in the Tile Adhesive / Grout Advice area at TilersForums.com.
My vote would be for epoxy. Is it a polished porcelain, tight joint? If so and you don't want or can't use epoxy then I'd be using a fine, smooth grout and sealing it. Granfix Maxi in white could be worth looking at.
Yeah I read that. Quite a purchase that for Instamac. Have they altered the product lines at all? I used to use Maxigrout quite a bit, found it smoother than Ultra.Under the Ultra label nowadays
Completely agree. Proflex, rapid and extended set are excellent as are their levellers. Always had half decent tech support as well.I like Ultra, their adhesive is good as well...
Are we looking for a flexi groutWhat has got to do with it ?
Porcelain tile so yes to flexiAre we looking for a flexi grout
Reply to White Floor Grout in the Tile Adhesive / Grout Advice area at TilersForums.com
