Discuss White Floor Grout in the Adhesive and Grout area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
james hailwood
Can anyone recommend a good white floor grout? It's for a brilliant white porcelain floor. I'm looking at a mapei flexi one but thought I'd ask on here to see if any one can recommend one.
One Day
I'd insist on an epoxy. Best white one I've used is Kerakol's.
(Micromax 2 white is more a silver grey - unless they've improved it)
Andy Allen
(Micromax 2 white isl more a silver grey - unless they've improved it)
Was white when I used it last week ...well as white as your going to get with a floor grout...
Rookery
I'd go for Ardex FL grout. In my opinion Mapei 100 is not as brilliant a white as I'd like. I'm not a fan of any Micromax. Microflex white is the only BAL grout I use but its for walls.
Rich Midge
My vote would be for epoxy. Is it a polished porcelain, tight joint? If so and you don't want or can't use epoxy then I'd be using a fine, smooth grout and sealing it. Granfix Maxi in white could be worth looking at.
White Room
Under the Ultra label nowadays
Reply to White Floor Grout in the Adhesive and Grout area at TilersForums.com
Apatel
