Porcelain White Floor Grout
Can anyone recommend a good white floor grout? It's for a brilliant white porcelain floor. I'm looking at a mapei flexi one but thought I'd ask on here to see if any one can recommend one.
I'd insist on an epoxy. Best white one I've used is Kerakol's.
(Micromax 2 white is more a silver grey - unless they've improved it)
I'd go for Ardex FL grout. In my opinion Mapei 100 is not as brilliant a white as I'd like. I'm not a fan of any Micromax. Microflex white is the only BAL grout I use but its for walls.
My vote would be for epoxy. Is it a polished porcelain, tight joint? If so and you don't want or can't use epoxy then I'd be using a fine, smooth grout and sealing it. Granfix Maxi in white could be worth looking at.
Under the Ultra label nowadays
White Floor Grout
Porcelain
james hailwood,
dbstiling,
james hailwood,
dbstiling,
