Can anyone recommend a good white floor grout? It's for a brilliant white porcelain floor. I'm looking at a mapei flexi one but thought I'd ask on here to see if any one can recommend one.
Discuss White Floor Grout in the Tile Adhesive / Grout Advice area at TilersForums.com.
My thoughts exactly, I spoke to the customer about a light grey as white will discolour but she was adamant to have white.I wouldn't use white on a floor. It gets dirty very quickly.
Was white when I used it last week ...well as white as your going to get with a floor grout...I'd insist on an epoxy. Best white one I've used is Kerakol's.
(Micromax 2 white isl more a silver grey - unless they've improved it)
What is the sub structure?
My vote would be for epoxy. Is it a polished porcelain, tight joint? If so and you don't want or can't use epoxy then I'd be using a fine, smooth grout and sealing it. Granfix Maxi in white could be worth looking at.
Yeah I read that. Quite a purchase that for Instamac. Have they altered the product lines at all? I used to use Maxigrout quite a bit, found it smoother than Ultra.Under the Ultra label nowadays
Reply to White Floor Grout in the Tile Adhesive / Grout Advice area at TilersForums.com
