Discuss Underfloor heating HELP!! in the Tiling on Underfloor Heating area at TilersForums.com.
G
GMajor13
I am hoping you can help me with my underfloor heating problem.
I am currently building an extension to the rear of the property and have now decided after the floor has been prepped and signed off to try and install underfloor heating. Floor construction is MOT, sand blinding, DPM, 100mm insulation and a further layer of dpm. This leaves 100mm to reach DPC. Almost all recommendations by suppliers say that 100mm is too thick of a slab to place underfloor heating in and to reduce this to use a screed,however this means that the floor will not satisfy the required 100mm under regs. I lf I was to screed on top this would raise the floor in comparison to adjoining rooms. Help!
Has anyone any experience of laying UFH in a slab this thick and achieved decent results?
If so what effect does piercing the second layer of DPM have?
Any other suggestions on how I can still achieve UFH in my situation?
Many thanks in advance, I hope someone can help!!
Dumbo
I don't understand have you got insulation under the foundation slab ( oversight ) most floor build ups are slab , dpm , insulation , slip coat (thin guage membrane ) then screed . My screed at home is a pumped screed about 55mm thick most sand and cements are about 75mm .
G
GMajor13
The floor is prepped to pour the floor slab.
The build up is;
MOT
Sand blinding
DPM
100mm insulation
DPM
This now leaves 100mm (required concrete) to dpc to fill with concrete that I would like to fit wet piped UFH in.
Dumbo
Sorry wasn't following mot as being scalpings . Just increase your insulation thickness
G
GMajor13
Thanks JCRtiling for your responses. Surely this won't work though as then I won't achieve the 100mm floor thickness BC require
Chalker
1,058
Tadcaster
Looks like your missing the 100mm oversize concrete!
His is how it should be done.
Dumbo
I just started typing when I saw new posts . So it should be . Mot . Sand . Concrete slab . Dpm . Insulation . Slip coat . Screed .
Concrete slab could be replaced by block and beam .
G
GMajor13
This is my current make up. Is there anything I can do at all? Thanks for all your help everyone IMG_1389.JPG
H
hmtiling
is the point here that the insulation can be over 100mm and 100mm is minimum requirement? therefore add more insulation as already stated?
Reply to Underfloor heating HELP!! in the Tiling on Underfloor Heating area at TilersForums.com
Hi there, hoping for some help here. I am about to install a small (2.2x2.5m approx) area of...
Hi All, I’m ripping out a failed existing tiled floor. Tiles had not been back buttered so...
