Yeah but then they wouldn’t be indestructible and would need a case. 😀Sigma needs a laser line...
You can make your own style of continuous line for the Sigma.Sigma needs a laser line...
Candlelight oop here in the grim North......I don’t tend to fix tiles by torchlight, I generally try to use a site light, LED if I can. 😀
But I do agree with Tom, casting a shadow does work very well.
If you quote one person its plagiarism if you quote lots of people its called researchI’m just an habitual victim of plagiarism
If you have the 1200 or bigger, drop the bar off so the staff can carry it, it’s so much bloody easier and lighter they'll appreciate it.
The bar weighs as much if not more than the base.
As a @Localtiler said in a previous post about this be carefull or your cut can be 1/4 of an hour out .I've used Lee Macs idea of using the shadow from the bar to cut. Just don't try it outside in the sun ( he's never had that problem being in NI..)
I do have a very basic tip that everyone will already know.....
The measuring bar can be stored on the main tile body. It slots in and screws on.
Setting the cutter properly is probably the most important for flawless results, I agree you can compare cuts with Rubi on biscuits but just wait till it’s full on porcelain the Sigma goes into overdriveSetting the height makes all the difference. Previously I was getting quite a rough edge on my biscuit. Now it’s set up properly, it cuts flawlessly. Identical to the Rubi.
Also had a proper look at lining up the tile with a pencil mark. Yes it’s going to take a bit of getting used to. One way I have found is to mark the pencil line down the biscuit so it lines up with the breaking bar.
Think I remember someone on here saying it didGuys- does the Montolit mosaic Matt fit the Sigma ?
iThink I remember someone on here saying it did
Haha you can not help yourself Antonio can you! 😛
try to put yourself in my condition ... without translate...Haha you can not help yourself Antonio can you! 😛
It is in your personality, you must reply! Haha 😀
bravo, number oneWell, that’s was interesting. I just spent the last hour cutting various thickness, hardness and texture porcelain with my new cutter.
I now understand the fuss about sigma being best, it’s effing amazing. Wasn’t 100perfect on heavily textured but on 10mm polished or matt porc it’s just incredible. Managed to cut 600 x 300 down to 10mm rips with ease
Cheers lads for suggesting it
