Discuss Sealing Porcelain Mosaics in the UK Tiling Forum area at TilersForums.com.
jgw1
When I had my 600mmx600mm black porcelain tiles the advice I had was to seal them. I am about to put up some porcelain mosaics.
Do these need sealing like the floor tiles? Will I have a problem wiping off the adhesive/grout if I do not?
jgw1
That's the difference thanks, the floor were polished but the mosaics aren't - thanks.
DHTiling
Not as easy as that.. some through bodied porcelain needs sealing.. but if they are glazed then no they do not..
jgw1
hmmm can I tell if they are glazed?
I am buying from a pretty good tile shop in East Sheen/Mortlake in London. They said that I didn't have to seal them - then again they said that I did not have to seal the polished porcelain tiles (the wife of the tiler who staffs the shop - you guys told me to seal - so I sealed :) )
A
Alberta Stone
Unglazed porcelain will still allow some water transmission, a very small percentage.
But it is a good idea to use a very good sealer.
Most water based sealers just form a thick skin on the surface and do not penetrate into the surface, so you need to do some research to find the best penetrator.
DuPont makes some good ones that are so effective often you cannot put on a second coat as it prevents absorption of more sealer, like this one: BulletProof® Sealer - DuPont? StoneTech® Professional
But it is for stone, however they ought to have one for porc as well
DHTiling
well they could be a through bodied one and IMO needs sealing( penetrating sealer for vitrified tiles).. but without actually seeing them then it is hard to see if your are right..
jgw1
I have a bottle of lithofin FZ Protective Impregnator W for porcelain tiles that I used fro my black polished porcelain floor tiles. That should work if I need to seal them.
How do I tell if they are glazed? Is there a way to tell? If not I'll ask the retailer but not sure they will know of the top of their heads.
Reply to Sealing Porcelain Mosaics in the UK Tiling Forum area at TilersForums.com
Hi, I‘ve just finished tiling the majority of my garden path. Base is concrete, and tiles are...
I've got an AKW Tuff form shower tray with a waste that is 10mm above the tray when fully...
