re grouting a bathroom, advice really...
mailsamwilliams
Hiya
New to the forums and after starting to dig out the old grout I am wondering if I have bitten off more than I can chew (so to speak!)
When my (ex) hubby grouted our bathroom tiles, he decided to do some weird grout and go thicker than all the lines should have been. Making it look a bit "rustic" so he said. :whatchutalkingabout
Now I can make decisions on my own about the house, I wanted to dig it all out and regrout it back to how tiles should look properly.
I am using the digging out tool and some of it on the edge and at the top is coming off really easy. Now I have got to the central part I am finding it hard to dig out.
I am also having to scrape it off the tiles as it was stuck all round the flat face edges.
Any advice really please.
hello and welcome to the forums......you can buy many types of grout rakes...but a masonry nail knocked through a piece of 2x1 is just as good....and when it is worn just replace with another....this is the cheapest way...you can also buy a fein multi-master but these are expensive if this is a one off job.........good luck.....
Good luck with the job. I think even most of the professionals would hate to do a regrouting job. Welcome to the forum. 🙂
As Dave says regarding techniques but i would warn you that this is a tedious job to do and wont be done quickly ,so all the best and welcome to the forums.
no I am realising this won't be quick!
I can't re tile it as I am a female with limited knowledge and the basic tiles are all ok, just needs re grouting, to look as proper tiles and grout should do! I will keep checking back here and thanks for the welcomes!
Being the nicest person on here i will make u a suggestion where bouts r u based
Iam sure there will b 1 gentleman tiler in the forum near by who wil do it 4 u
for a nice cup of tetleys tea and a chocolate biscuit
Can't c a single Damsel in Distress
lol Raja, if you would be happy spending a couple of days raking out grout for a cuppa n biscuit then get yourself round there.
Re-grouting is a horrible job to do even for good money as you really have to remove as much as possible for the new grout to take into the grout lines.
But if you are not bothered how long it will take to do then it's not a difficult job to do, just very time consuming, and does have the chance of you slipping with whatever you use to rake out the grout and damaging surrounding tiles.
Good luck and welcome to the forums
Regrouting holds second place on my list of tiling related pet pews. If I were you, I'd rip the whole thing away and put in new tiles. Otherwise, I'd rent an electrical grout remover, such as a Fein Multimaster, or a reciprocating saw with a "grout grabber" attachment. If you do that, don't forget to wear appropriate protective gear, and to seal of the room which you're regrouting completely, as the dust will get everywhere otherwise.
Welcome to the forums 🙂
Thx Fekin 🙂
Here's a vid of the "grout grabber" solution. Still a bloody tedious and messy job though.
[DLMURL]http://www.youtube.com/watch?v=LIXUfOj_m_I[/DLMURL]
[yt]LIXUfOj_m_I[/yt]
Thanks Raja for your "suggestions" hehe!! :lol: I don't think I would like a strange man popping round from the internet :uhoh2:
That grout remover looks good! looks like it should have a hoover attatchment on it to catch the dust!
What happens to the tile spacers, it must mash through them also :huh2:
I think I will just have to stick my head down over the next couple of days and just be patient in the knowledge that this is a tedious and boring job!!!
Thanks for all your replies, I will let you know how it goes!
PS - can you post pictures on here with an IMG tag?
Strange men where ?????
None on here mind u there is 1 really stunning looking one who has a way with women avoid him
goes by the name of erm erm let me think erm ohhh forgot :lol:
yes I did think about the "strange men" comment, as I was posting that! Although it was meant more tongue in cheek, as Raja was being cheeky (and still is) :tt2:
Well this morning I am back at it, and it is worse than watching paint dry! The tough bits are slowly coming away with a bit of elbow grease (which as a weak limbed female, is hurting my pointy finger) :grin: I can see me being here a while!!
FYI - this is how bad the grouting was and some of the bit I've dug out (does that look ok to regrout?
I know!!!! I have hated it since it was done!! :whatchutalkingabout what a stupid idea in the first place and it made it so hard to clean, as grout looks cr4p anyway IMO!
pah - I think the likelyhood of me tackling another job like this ever again is non exsistent :lol: it's more a case of "I've started, so I'll (have to) finish!!!
I have to keep stopping for little breaks to give my fingers a rest! :grin:
but I will post a photo afterwards to show you what girl power can do!!!:hurray:
on a plus note, I have just come across another bit that is coming out easier, it's just those stubborn tough areas nearer the bottom - is there a reason that bit is harder to do? more water contact :huh2:
Precisely.
Fresh grout doesn't "dry" per se when you apply it; it cures. That means the cement in it reacts with water, chemically binding much of it. If grout "dries", by which I mean it loses moisture too rapidly (the substrate might too absorbant, the temperature is to high, sun shines directly onto it for the first few hours/days, etc), the result is often weak, and more easily damaged. This is why many manufacturers recommend that you keep freshly grouted surfaces damp for two or three days after application; the result is tougher and more durable, as it the additional water allows it to cure properly.
The grout being harder close to where it's been subjected to the most water is therefore logical.
ah!!! ok that makes sense - thanks!!
I am at a give up point today, seems to be this time of day I lose the plot!
Might be moaning on these forums for a few more days yet :13: so please bear with me :thumbsup:
That will look fine i think , once you grout up....and as for you never thought you would find your self on a tile forum...then thats wot they are for....and you came to the best one........good luck and look forward to the photo's of completed job.......
yes you have all been very helpful!
Thanks for all the advice :thumbsup:
Any time for a lady who thinks we r strange men :lol:
Stick with us after r grouting is finally finished
as we can advice in all areas there is a wealth of experiance on the forum
Each member has somthing special to offer my speciality being more of a erm well how can i put it erm
Ladies Man Maybe :lol:
All the best
hehe! you have made me giggle with your comments, so that can't be a bad thing! :yes: need all the encouragement I can get with this boring job on hand!!!
from the woman with grout dust in her hair :lol: (I would imagine - just the way you like em on here) :hair2: any excuse to use your cool emoticons! :grin:
First rule of the game if the lady smiles half won over :lol:
Listen lady u wil find i am a conasour of only i repeat ONLY fine women
U would have to pass strategic tests b 4 i liked u like can u iron? cook? clean? etc only then would i let u stamp my card:lol:
Bathroom Tiling Advice
Unsolved
mailsamwilliams,
sWe,
mailsamwilliams,
sWe,
