plasteringtiler
Hi guys,
Just need you to clarify something. I need to quote for a 3sqmtr floor in quarry tiles on a cement base in a porch. Customer hasn't decided on which make of tile yet but has looked at the Toppstiles selection which i assume is Ruabon (have looked on the Ruabon website and they've obviously been tested using Ardex). As this will be my first "real" flooring job i am obviously nervous and excited and most importantly want to do it right! So my question is, i am thinking of using Bal single part flexi or Bal rapid set flexi adhesive (depending on the external temperature ie it was 28 degrees yesterday so in those conditions would use single part flexi) using a 20mm half moon trowel with 5mm grout lines, primed with Bal Admix AD1 and grouted with Bal wide joint grout. Am i on the right lines or am i barking mad? thanks in advance
