Discuss niro granite help please in the UK Tiling Forum area at TilersForums.com.
sstilingservice
Hi i am just starting out for myself and a bit nervous . just been round to my first potential customer to quote for a job . the tiles are called niro granite but look like porcelain am i right do they do granite effect tiles . just want to make sure i don't come across as a novice to the customer so could not um and ar to much the tiles look like granite but have a manufacture marks on the back which make me think they are porcelain would i be right in my thought's . granite will needed to be cut on a wet cutter and porcelain on my rubi any help / advise would be great nervous newbee tiler
MICK the Tiler
If they are stamped on the back then I would say porcelain as these are pressed clay, marble and granite are usually smooth on the back. But then again they could be reconsituted granite which would be pressed and would need wet cutting. Don't be shy if you don't know a particular material let the customer know try and cut one dry if it won't cut then make allowances for wet cutting. I've been doing this for 20+ years and still haven't seen every type of material let alone laid all types. I still see new types all the time.
sstilingservice
thanks mick they are pressed on the back which made me think they are porcelain but could not see anything on the box to verify my thought probably be fine its like you say their is a first time with any new material just a bit nervous about my first quote ( bricking it ) i think is probably closer to the mark ! just have to see what they think of my quote difficult trying to be competitve but not to cheap soon find out i suppose fingers crossed thanks for not making me feel a bit more confident
steve
wetdec
Niro Granite is a Swiss product manufactured in Malaysia and distributed in the uk by Pilkingtons. Its a high quality porcelain tile so should be treated as such.
You can find a data sheet in the pdf section
cheers
tiler
sstilingservice
hi wetdec thanks thats the answer i was looking for thought that was the case just questioning my self noow i just have to come up with a realistic price more uming and arring
R
Ronald Parée
Porcelain, technological stones, etc. can be cut on site dry with the right equipment!
Today even the 1200*600*11 or 12 mm tiles can be done (cutter length ca. 1350 mm! as well as full vertrified 14, 16 or 18 mm thick tiles
sstilingservice
Thanks for the help ( but have you looked at the date ) :8: have a beer for trying
R
Ronald Parée
I know\knew.
Today a got subscribtion to Tiling Forum only and "saw" your message.
Better a late answer (to you and all the others) than no (professional) answer!
A cold Grolsch (Dutch) beer would be appriciated!
Reply to niro granite help please in the UK Tiling Forum area at TilersForums.com
Hi, it's my first time here and I'm desperate to solve this problem. Can someone please tell me...
Hi everyone. I'm really hoping you all can help as I am at my wits end. We have hired...
Hi all. I am tiling my bathroom after removing old suite. I have used a batten all the way...
Moved this as I incorrectly posted in the Pro forum! Hi all, Finally getting to lay the tiles in...
