Tiling Tool Suppliers
Discuss Help with Plasplugs Contractor Diamond Cutter in the Tile Cutters (Manual & Wet Cutters) area at TilersForums.com.
Mad Hatter
I've got the same cutter. For sockets that require a plunge cut I usually mark lines on the tile with a square and then line the tile up in the centre of the cutter using the ruler on the machine and slowly lower the tile onto the cutter, when the tile starts to cut through just move up or down as required and repeat on the other three sides and don't forget a waterproof jacket as you'll get slighty wet!:lol:
I've to admit when you are doing 10+ sockets a day the noise of the machine can cut a but too much and I came home yesterday with a banging headache, other than that I cant fault it and it has tackled everything I've thrown at it.
Reply to Help with Plasplugs Contractor Diamond Cutter in the Tile Cutters (Manual & Wet Cutters) area at TilersForums.com
Hello, I hope you can help. I'm get despondent cutting 9mm glazed porcelain tiles, 300 x 900mm...
Hello, this is my first post so here goes, advice needed. It was decided that I should renovate...
  • Sticky
I really need some sound advice as I’m well out of my depth. We have a little second home with...
I searched but did not find an answer. I been advised to get a wet tile cutter, I plan to cut...
Popular Tile Cutter Threads
    Votes: 5 5.0%
    Votes: 8 8.0%
    Votes: 6 6.0%
    Votes: 24 24.0%
    Votes: 14 14.0%
    Votes: 28 28.0%
    Votes: 3 3.0%
    Votes: 2 2.0%
  • Tilemaster /Kelmore
    Votes: 19 19.0%
    Votes: 18 18.0%
    Votes: 11 11.0%
    Votes: 5 5.0%
    Votes: 3 3.0%
