Discuss Bathroom tiling adhesive and clips advice. advice and in the Adhesive and Grout area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
M83T
I have been asked to tile my cousins bathroom and it will be my first time using 300x 600 ceramic for the wall. The tiles are going on a skimmed wall which is in good nick, can anybody reccomend a decent slow setting adhesive to use for this please. And also is it worth using clips to get them good, it's not a huge area but I do struggle with lippage because I'm still very much a learner. I haven't said yes to doing it yet but I am keen to try it for some experience, any advice on the above or anything else I should consider? Thanks
M83T
Tilemaster setaflex standard set is a good adhesive to use.
In regards to clips each member has there own preference mine personally is perfect level master.
Thanks! Does the setaflex have a decent working time, I've just done some travetine for someone and the adhesive they supplied went off so quickly it really caused me some headaches!!! I was vying toward perfect level master.
G
GoneGuy
It’s around 3-4hrs in the bucket, I tend to give it a whirl with the mixer after an hour.
In the summer it’s around 2hrs depending on temperatures
M83T
Great thanks, also just a quick question should I tank the walls or use some form of waterproofing prior to tiling? They are plastered block walls.
Spare Tool
Skimmed walls generally appear good till you get a straight edge on them, especially around the windows, spend some time doing this and after priming skimming out any dips with adhesive..it'll save you a lot of headaches later on
:thumbsup:
M83T
:thumbsup:
Agreed I will have a good check, they are ready to move in and unfortunately have left the bathroom until last so they are in a rush to get it done I'm going to tile their kitchen but I'm unsure about the bathroom walls above the bath, I was going to SBR the walls then tile but should I waterproof the walls for the over bath shower??
Spare Tool
If the bath is being used as a shower then yes, the Tilemaster waterproofing kit contains everything you need..
Reply to Bathroom tiling adhesive and clips advice. advice and in the Adhesive and Grout area at TilersForums.com
Northern Tiler
