Discuss 3mm tub adhesive versus cement ad in the Tile Adhesive / Grout Advice area at TilersForums.com.
Stevev
488
Blandford forum
What is the advantage of using tub adhesive which typically is spread at a 3mm thickness over cement adhesive which I was trained to use at a thickness of 8mm. I was told once the tub is open it starts to go off and a slow/amateur tiler would be better with cement adhesive. Discuss!!
L
LM
There is no advantage!
Dumbo
When you say 3mm you surely don't mean a 3mm trowel . Cement adhesive even if slow set will go of quicker than air drying ready mix
Stevev
488
Blandford forum
Am I the only person that has read the instructions on these tub adhesives?.....they state a 3mm bed with a square notched trowel or use the spreader supplied. Also says open time of 20-30mins...although I know someone who used it for hours...will the whole tub really be un-useable in 20 mins?
Open time is different to pot life!
Open time is the amount of time when it has been spread on a substrate, not in an open tub.
So, no, you're not the only person that reads instructions, its just that some understand it better than others.
Reply to 3mm tub adhesive versus cement ad in the Tile Adhesive / Grout Advice area at TilersForums.com
  • Poll
