365 drills
  • Thread starter Thread starter chrisroe
  • Start date Start date
  • Tags Tags
    usa
C
chrisroe
just a quicky
need to drill 4 holes in a granite worktop 40mm wide ( hole width not worktop )
if the 365 drill bits dont have a core drill before and the template only goes upto 30mm how do you start it ?
I'm near certain the bathroom kit has a 40mm bit in there.
I have two sets lying in my drill box.
sorry i cant even give the right info
its 45mm so i presume if you buy the 45mm one they come with their own guide to suit
Too much beer watching the rugby yesterday
This is the 45mm pack
It will give you 4 x holes in very hard granite worktops.
Example of a granite worktop before drilling:
You can drill the granite worktop in situ if you need to (if it cant be moved)
Or take it outside to a source of water (this top is also above the drain)
Drill your hole in the granite with the water cooling the core
Result after about 6 minutes of drilling. The other 3 holes will be as easy
Fit your appliance (In this case its a 45mm waste trap)
[video=youtube;NjuUmSksArQ]http://www.youtube.com/watch?v=NjuUmSksArQ[/video]
The "How to" Video if you need it
365 drills
Tags Tags
usa
chrisroe,
Deleted member 1779,
chrisroe,
