20mm exterior porcelain cutting
Lakey
quock question.
What is the best way to cut 20mm external porcelain?
Is there a mini grinder blade that will cope?
Cheers
Not entirely sure yet.
20mm dry cut tends to overheat the blades,
the black blade in the trend posted above
it's the best I've tried.
also montolit tcs 115 is good.
otherwise if you have a water saw, use that
quock question.
Cheers
One of these will cut 20mm porcelain The Rubi TZ
Yeah we don't sell Diatool blades, you'll find Diatool sell Diatool blades. We can't sell you something we don't make.
On the whole 20mm Porcelain is better cut wet rather than dry with a grinder.
The 2 blades you sent me to test were both superb Alan. The quality and speed of both were superb on 20mm. I've also tested them on various other tiles and without a doubt they would be my first choice replacement s if you decide to stock them
Thanks Pete, we're still testing. Once we've got the right one that's correctly certified and tested for sale in the EU/UK we'll be offering it.
ThatsView attachment 103140Thats the red blade on the Flex Alan, can't tell it apart from the factory edge
That is clean, much cleaner run wet than dry. The increased diameter and fact it's held very straight in a rail saw also helps a huge amount.
Either of these are looking promising.
I'm interested to see how you get on with the black blade.
Speed/ease of cut is also a factor, if there's any difference it's good to know.
What blade was that please and size
It was a blade we're testing and sent out to a few forum members.
This particular one would have been 150mm x 22.23mm which I asked Pete to run in the CS60 he'd bought recently. Whichever blade we decide to proceed with will be available from 115m up to 350mm in diameter as we're being asked constantly for a blade specifically for 20mm porcelain.
The process of manufacture means the 20mm stuff seems to be much more dense than grade 5 porcelain that we're all used to so it appears the bond on the blades need to be adjusted to suit.
The upside of this is these blades may also work well on regular grade 5 material, it's a bit of trial and error in reality.
Are you happy with the flex? It's on my radar
Think of the CS60 as a landscaping/stone masonry product that can be repurposed for tiles.
Most of these we're selling now to deal with 20mm Porcelain after landscapers have given up trying to cut large slabs accurately with 9" angle grinders.
It's a substantial bit of kit, it's outdoor use only and makes a reasonble mess with constant water flow.
For regular tiling it's probably overkill.
For lots of 20mm Porcelain, large format slabs or stonework it's outstanding.
It would be solely to take place of a 1200 bench saw for stone and 20mm porcelain.
It's ideal for that, we used to cut up 30mm thick granite slabs with one using two 1600mm rails and a coupling.
A good set up is the saw, 1x 800mm rail 1 x 1600mm rail plus a coupler. That gives you 800mm, 1600mm & 2400mm cutting capabilities in one tool.
Despite coming with a 170mm blade, it will take a 180mm blade without any snagging which opens up the options tremendously.
Lakey,
peteablard,
Lakey,
peteablard,
