Just called ATS who were no help at all. Which blade would you recommend mate?
do you have to make a lot of cuts?Just called ATS who were no help at all. Which blade would you recommend mate?
Not entirely sure yet.do you have to make a lot of cuts?
Don’t think there will be loadsNot entirely sure yet.
20mm dry cut tends to overheat the blades,Not entirely sure yet.
Thanks mate. Much appreciated20mm dry cut tends to overheat the blades,
the black blade in the trend posted above
it's the best I've tried.
also montolit tcs 115 is good.
otherwise if you have a water saw, use that
quock question.
What is the best way to cut 20mm external porcelain?
Is there a mini grinder blade that will cope?
Cheers
Yeah we don't sell Diatool blades, you'll find Diatool sell Diatool blades. We can't sell you something we don't make
On the whole 20mm Porcelain is better cut wet rather than dry with a grinder.
moneybags!View attachment 103137One of these will cut 20mm porcelain The Rubi TZ
🙂moneybags!
The 2 blades you sent me to test were both superb Alan. The quality and speed of both were superb on 20mm. I've also tested them on various other tiles and without a doubt they would be my first choice replacement s if you decide to stock themYeah we don't sell Diatool blades, you'll find Diatool sell Diatool blades. We can't sell you something we don't make.
Hopefully trying bthe black one on the Flex next week, will let you know how I get on. Have been more than happy with the red one so farThanks Pete, we're still testing. Once we've got the right one that's correctly certified and tested for sale in the EU/UK we'll be offering it.
ThatsView attachment 103140Thats the red blade on the Flex Alan, can't tell it apart from the factory edge
Cant remember mate ,just used a fine 9inch concrete blade contact theblade guy on hereWhat blade did you use?
What blade was that please and sizeThatsView attachment 103140Thats the red blade on the Flex Alan, can't tell it apart from the factory edge
Are you happy with the flex? It's on my radarThatsView attachment 103140Thats the red blade on the Flex Alan, can't tell it apart from the factory edge
It would be solely to take place of a 1200 bench saw for stone and 20mm porcelain.Think of the CS60 as a landscaping/stone masonry product that can be repurposed for tiles.
Most of these we're selling now to deal with 20mm Porcelain after landscapers have given up trying to cut large slabs accurately with 9" angle grinders.
It's a substantial bit of kit, it's outdoor use only and makes a reasonble mess with constant water flow.
For regular tiling it's probably overkill.
For lots of 20mm Porcelain, large format slabs or stonework it's outstanding.
