Anhydrite screed prep
To use “traditional” prep methods The surface needs to be clean sound and absorbent. As the surface is currently solid it is definitely sound. Clean … well that’s fairly straight forward… A simple test for the level of absorbance is the water drop test. Get a few drops of water (you could use perhaps a spent lateral flow test bottle or similar) to put a few drops of water on the surface of the screed. It should soak in pretty much immediately. This, when you prime it allows the water in the primer to dial in pulling the polymer in as well. If the water sits on top of the surface for more that a couple of seconds it’s not absorbent. You can get specialist primers for non absorbent surfaces but I’ve never had much success with them. So you are best to sand/grind it to open up the surface a little and make it more absorbent.
Alternatively you could use a pressure sensitive vynil flooring adhesive to stick down the sites matting.
Final alternative you could use bal flexbone and avoid any prep at all.
Cheers👍
Passes water drop test no prob. Gone for a Weber primer/ sealer & SPF.
I'll crack on with the 40grit as planned
Cheers👍
In case it may help someone I ended up using a grinding cup on a 4" grinder attached to hoover via a dust collector. I had forgotten I had these. Took no time at all just a matter of keeping the grinder level & moving at steady speed - backwards & forwards easier to control the grind that arcing from side to side.
Cheers for the advice - always grateful when people give their time for nowt to save others wasting theirs👍
We have a new Anhydrite screed floor with Wet Under Floor Heating and planning to stick 60x60 Ceramic Tiles on this. The floor is being sanded on Monday and then the question is whether or not we need to prime the floor before tiling?. We have had a lot of conflicting advice regarding this. Can any one tell me step by step what I need?
We have a new Anhydrite screed floor with Wet Under Floor Heating and planning to stick 60x60 Ceramic Tiles on this. The floor is being sanded on Monday and then the question is whether or not we need to prime the floor before tiling?. The floor has not yet been commissioned. We have had a lot of conflicting advice regarding the primer Can any one tell me step by step what I need to do to ensure I do things in the right order? TIA
Commission heating before doing anything. Check its dry, sand it, vac it, prime it with an acrylic or sbr primer, then tile it using either a gypsum based tile adhesive direct to the screed or a gypsum based adhesive to stuck down an uncoupling membrane and then a flexible cement based adhesive on top of the uncoupling membrane.
Silane,
Ajax123,
Silane,
Ajax123,
