Discuss What tool to use for cutting trim mitres in the America area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
Hi all. I hope you are keeping well. Need a bit of advice on which tool is best to cut the mitres on metal trim. Can you get a good blade for an angle grinder or is there not enough control with this? I don't have a small chop saw, only a big sliding mitre saw which a blade would be very expensive I believe.
Thanks all
Dave
Thanks all
I just use a standard hacksaw with hss blade in and a mitre box. The thing is with grinders etc as you say is stability and the risk of kick back.
Well, I must admit, I was not expecting that as a recommendation. Old school. Rhing with me is I have never been able to cut a good mitre using a mitre box for some reason. And hacksaws I am useless at cutting in the direction I want.
Dave
I use a file to dress the mitres if required, the genesis mitre box is perfect for holding trims.
faceman
a good thin angle grinder disc is ideal. Battery grinders are easier to work with as they aren't as aggressive. There is a knack to it so you don't get a kick back but you'll get it eventually. A hacksaw and good block still gets me by but if you need a fraction cutting off to give you a perfect mitre you'll struggle. There's always place for a metal file in these situations plus you'll need one for removing tiny burs on the edges.
Reply to What tool to use for cutting trim mitres in the America area at TilersForums.com
laattaana
