Discuss What could be causing this? - damp behind tiles? - wet grout in the Adhesive and Grout area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
I specialise in rip outs ( a lot here do so I’m not boasting) back to floor and walls for re fits. To be honest. It’s the best way in some situations.
I agree, I think the only way to get the tiling done correctly is to rip it all off, plaster the walls flat, not leave old adhesive, blown skim and good skim then spray it with some sort of bonding - then 'mark' the room square virtically and horizontally then set the tiles and this time, apply the tiles onto a nice flat surface.
acaciaguy
Strip back to brick. Then either dot and dab appropriate plasterboard or use a cement board. You can batten wall out too. Don’t bother with bonding and skimming
All four walls and window recess are like the picture below.
Reply to What could be causing this? - damp behind tiles? - wet grout in the Adhesive and Grout area at TilersForums.com
Apatel
