What could be causing this? - damp behind tiles? - wet grout
It looks like water seapage coming through the grout, but cannot feel any wetness. Water pipes are below the tiles pictured. Could it be dampness behind the tiles through poor prep work?. I don't know to be honest, so am purely guessing from logic. This first appeared 2 days ago. (Part of an ongoing issue with poor workmanship/prep work)
Is the discolouration permanent or does it dry out back to its normal colour? Is it in a shower area?
This is new discolouration. It looks like it is wet, so unsure if moisture behind the tile. So far, it has not dried out. There are other areas of discolouration that have been there for a couple of weeks and has been raised. These are new.
The shower is not yet installed.
If the shower hasn't been used, it's more likely to be inconsistently mixed grout, maybe too wet or washed too soon, or washed with too much water releasing pigments. Take a bit of medium "wet and dry" and gently sand a small patch, see if it goes back to the intended colour, and if it does, keep an eye on it and see if it goes dark again. I think if it was water behind the tile, it would more likely soak the full width of the joint, not just down the sides of it.
Tiler is coming back tomorrow for 2 days under instructions, so will see what happens. (not much hope anything will change for better, but...)
I agree with Paul c. If it was a leak it would be wider spread and you would need to take a tile off to investigate. What are the other issues? Are the other places with similar grout issues
The whole bathroom needs ripping out and starting from plastering the walls to make flat, as should have been from the start. Not doing that has left lippage all over, uneven tiling, badly fitted trim, badly cut tiles, uneven tile spacing etc... 🙁
So sorry to hear that. Where are you based?
I specialise in rip outs ( a lot here do so I’m not boasting) back to floor and walls for re fits. To be honest. It’s the best way in some situations. I’m in Warwickshire but you will find someone great in this site.
I agree, I think the only way to get the tiling done correctly is to rip it all off, plaster the walls flat, not leave old adhesive, blown skim and good skim then spray it with some sort of bonding - then 'mark' the room square virtically and horizontally then set the tiles and this time, apply the tiles onto a nice flat surface.
Strip back to brick. Then either dot and dab appropriate plasterboard or use a cement board. You can batten wall out too. Don’t bother with bonding and skimming
Their work:
Looks like the tiler has just followed the contour of your bad walls.
Maybe they should have said to you when starting or looking at the job that your walls are out of plumb do you want use to follow the walls or knock all the render off back to block and re-board it to make it level. This would cost a lot more money this way.
snackeroo,
Dumbo,
snackeroo,
Dumbo,
