Discuss Cost effective tile cutter for 600x300 pocelain floor tile cutter in the Tiling Tools | Tile Cutters, Trowels area at TilersForums.com.
Colo
233
Durham
Hello,
I am about to do my bathroom floor and need a porcelain tile cutter.
is the Big Clinker any good as it will only be used infrequently.
https://www.NoLinksToThis/p/big-clinker-2-heavy-duty-tile-cutter-630mm/29758
Thanks for any help.
Andy Allen
1,318
Gloucester
If it's a one off job, and you have a grinder or can borrow one, get a decent blade for about 20 quid and Bob's your uncle..!
Colo
233
Durham
Thanks for that Andy,
I did try a small angle grinder with a 110mm marcrist diamond blade but it was a terrable cut.
Can you please recommend one i can give a try.
Andy Allen
1,318
Gloucester
Turbo X Diamond Porcelain Blade
Home / Cutting / Turbo X Diamond Porcelain Blade
Turbo X designed Diamond Blade for angle grinders particularly for cutting hard material such as porcelain, hard ceramics and quartz. Only 1.2mm thick and with a 10mm high segment giving fast clean cutting and a long life. Available in 115mm and 125mm.
These are good blades from ATS diamond tools..
(Ignore this first link, my mistake)...:)
Colo
233
Durham
Thanks Andy that looks just the job.
I have an old Ishii Big Clinker and to be honest it does the job. It looks like the Big clinker 2 from screwfix.
I will have a try with that and the angle grinder and see how I get on.
Thanks again
Col
Reply to Cost effective tile cutter for 600x300 pocelain floor tile cutter in the Tiling Tools | Tile Cutters, Trowels area at TilersForums.com
