Silicon removal, light film on edges
I have recently done a job where I have siliconed like normal after a job and have noticed that because the tiles have small dimple patterns on that Silicon has just stayed there. Also there is a light film down each side of the corner where the Silicon tool has left it.
Iv never had this issue before and need advice on removing Silicon. We have tried the Silicon cleaner from screwfix but nothing is coming off and friction isn't really doing it and because if the type of pattern I can't put a blade behind and peel it off
Does anyone know a sureway of removing the Silicon even if I have to remove all of the corner beads. I don't want to be buying loads of stuff and it not working
Any help would be great thanks
Not sure why the Screwfix Silicon remover hasn't removed the Silicon.....I have used it many times and prefer using it to other brands
I find sometimes the Silicon tools can leave a film which you can’t see until it gets dirty, unless you spray washing up liquid on whilst tooling
Thanks for the replies guys. I think I will order some of that and try it.
Iv never had issues with the film before but as mentioned about using soapy water I think I definitely will in future. I hate Silicon with a passion but have never had issues like I did on this job
The customers are a nightmare. Always try to pick fault and make people work more for their money, I took extra work off a friend at the house and wish I never bothered as me, the builder, plasterer and electrician have all had issues with them
Iso is also the best for cleaning up epoxy residues.
Just don't for heaven's sake put it in anything which you or someone else might drink from (...as I once did).
And if you shop around you can get 25ltr containers.
-=HaZ=-,
One Day,
-=HaZ=-,
One Day,
