Blunt Tool
Got some samples today to try. Kerakoll bio gel no limits white and Kerakoll fugabella white grout and Silicon. If I like then I can get a constant supply so hope it's as good as I've heard and read!
Where you getting the samples from? Trim traders have started stocking no limits, there near me
You should give it a try.Where you getting the samples from? Trim traders have started stocking no limits, there near me
The white grout I've been given is cement based but no sand it's got marble dust instead.There are 3 types of fugabella.
Best to avoid fugabella porcelana.
is with a lime base, I tried all the grouting systems,
Hard, liquid, clean with so much water, clean with little water,
Many tiles here, they avoid it.
The color, everything always remains to spots.
Even nolimits white to marble dustThe white grout I've been given is cement based but no sand it's got marble dust instead.
So, what's the low down with the no limits ?
From what I've been told, long pot life, can even add more water as never shrinks, very smooth no sand, instant grip and non slip, more wet than cement based flexi adhesive means more coverage under tile and comes in 25kg bag more for your moneyLooks ok!
Think it will be easier to source soon enough as have heard they are building a new factory in England to produce no limits.
Same price as 20 kg bag of Mapei, BAL S1 standard set so I'm toldDo we know what sort of price ?
They will be pushing now after heavy investments hereMust be hammering it out I got a bag too 😉
Looked prety good gear when the rep was using it .
He could come and tile one of my jobs for me in it![]()
For 12 € is stolen. 😉H40 No Limits is lovely stuff. As smooth as Andy Allen talking a client into having metros, as grippy as TJ holding a fiver at the bar and dries as hard as 3fall makes all his work look.
I pay €12.
Yes, I believe in what you say.
Otherwise, you can always bring me an nv200, full loadStrange how it's cheaper here, I get it for the same price from 2 different suppliers.
I'll check a bag to make sure it's not a Spanish copy!
