Discuss Schluter adhesive "thinset" in the Tile Adhesive / Grout Advice area at TilersForums.com.
Dan
Admin
1,318
Staffordshire, UK
I've read about it on the JohnBridge.com forum. That process of waiting then mixing again is quite common over there apparently. But I think there's one now where you don't need to do it if I read their thread right. I'll try find it when I'm back in work.
L
LM
Are you talking about 'slaking' Dan?
When you mix a product with water after the initial mix you let it stand or 'slake'
Reason for this is so that the adhesive/grout can fully take on the liquid.
Once stood, then you can remix and add extra liquid if necessary.
By now the mixture has absorbed the liquid completely leaving you with a consistency that will remain until the product begins to 'cure'
Yes it happens immediately, but there is that delay before it actually takes hold.
Well that's how I understand it anyway.
Italy
Once stood, then you can remix and add extra liquid if necessary. (afther the remix????)
Google marc says: add liquid after remix
Google not listen! :)
Mescolare l'adesivo con il liquido. Attendere 3 - 5 minuti. Riagganciare l'adesivo, aggiungere il liquido se necessario. Non aggiungere nuovamente il liquido.
mix the adhesive with liquid. wait 3--5 minutes. re-mix adhesive, add liquid if required. do not add liquid again.
Reply to Schluter adhesive "thinset" in the Tile Adhesive / Grout Advice area at TilersForums.com
