How best to Tile a room?
well they have levelled out the floor to the floor in the other room which I asked for, I bought the underfloor heating towards the latter stages of the build and only started my research then, so at that point I wasn't aware I'd need insulation boards or slc, and I don't think they have dealt with underfloor heating so they weren't aware how much tolerance to leave either, no the floor height wasn't on the plans.
But if you would have a got a pro tiler in, just to look at the job he/she would have told you from the getgo about height tolerances.
yeah in hindsight, the trouble is that I didn't even think about tiling and floor height until the floor was down, doh! maybe somekind of decorate strip can be put on the side so you don't see the layers when your looking from the garden in.
Get an artist (a pro one) to paint a tile effect 1 metre from the bi-fold doors........
@Tom Astley
How far into the room do the bifold doors come when opening and closing? However far they come in your not going to be having any tiles basically.
Such bad planning imo, your obviously spending a lot of money and it's a shame for the finish to be compromised
Yes but my question is still unanswered.
At some point in the build, finished floor levels must have been discussed, were they not?
Yes I understand you'd asked them to bring floor levels to the same height, and rightly so.
Was this asked for before the doors went in?
Do you have plans, or they winging it?
I'm actually serious.
Finished floor height must be written somewhere.
Even if it's only the height that they leave it at!
What is the height of the door above the boarded floor? I know I've already asked, couldn't tell from your image. Must have something you can use as a reference.
The point I'm trying to get to is that, if they just fitted the doors as they saw fit, and not to any spec or instruction, they're wrong and should be made to change it.
If I just laid a floor with no regard to floor heights and I was too high or low, I'd be responsible for putting it right, simple as.
I understand that it's not an ideal situation, but considering the bifolds open out, and it's just a 5mm gap, can't I just caulk it or get a strip to cover the edge?
If it is going to be higher than the threshold of the bifold doors, it's not going to look all that good if I'm honest, you could finish the edge with a metal trim but again I wouldn't be happy with that a finish. How much higher than the threshold are you going to end up?
There seems to be some confusion about what your problem actually is. If it's the tiles up to the door frame then you'd Silicon it anyway.
Well yeah I was going to use a 5mm edging strip and tile up to it, so the only issue will be that the finish floor level will probably be where the red line is on the pic, the doors open out, so that is it really.
That last wooden board up against the door, what are the dimensions of it? does the near edge line up directly with the corner of the wall (bottom right of the pic)? and can you unscrew it, lift it up and show us whats beneath?
I'm wondering if it can slope down to the door to a small degree by chiselling down whatever is under it, bracing it, screwing it back down, then tile/insulation joints sitting directly above the joint in the board and fill with colour matching Silicon to cater for possible movement?
Not seen it done before but could be a realistic possibility....... couldn't it?
Underneath the board is new joists, and 100mm insulation foam,
Yes i believe that board does go along to the wall, It's an idea, but I'd like to keep the floor as level as possible, with an already hard task I'd like to try and keep it as straight forward as possible, it might not come as far up as the red line, I'm just guestimating atm.
You are going to need at the least 20mm from floor,6mm boards, ufh matt, slc then tile .
If you ain't bought the tiles you can get some porcalthin tiles off @Ray TT @ Porcel-Thin .
How thick is the bead ? You may be able to just get away with it .
You can also flag outside up to the same ish height.
Me and @Andystiletiling did one, tiled it flush with the doors. So when the dots fully opened the outside became one with the inside 🙂
I've just swept and cleaned entire floor space with a wet sponge, once it's dry can I put the heat resistant primer down? even if I don't get round to putting down adhesive/insulation mats today?
As long as it's not going to be trafficked too much you should be fine. If it's going to have dusty boots all over it it'll be a waste of time. Personally I always try to prime day before I start.
I'd definitely be looking at sloping your last row of tiles down to be flush with bifold rail as Paul suggested, just leave your ufh and SLC back a foot or so, it'll look miles better from outside than a big trim or whatever your planning when the doors are open.
Did this one this year and its quite a bit more of a slope than your looking at but sometimes its a case of make do with what you have to work with and find solutions..
So I put down some insulation boards earlier, it was keraquick s1 flexible adhesive 20kg mixed with 5.2 litres of water, I certainly learnt a few lessons today, I used a 6mm notched trial, and back buttered all boards, it was all a bit frantic, I believe I have kept about 5mm around the edges free from board but not free from adhesive, does this matter? Although I believe I was fairly consistent with the mix I can see one or 2 slight ridges, this time I was on my own and it was rapid set, for laying tiles I'd have someone with me, I wouldn't be using rapid set and id be using levellers inbetween the tiles, I've only put down 7 boards so far so I am hopeing by the time I've laid them all I'll be a lot better at it.
DIY Tiling Forum
mp3wizard,
Time's Ran Out,
mp3wizard,
Time's Ran Out,
