Discuss Unfilled Travertine? in the Australia Tiling Forum area at TilersForums.com.
I'm to do a job shortly where the travertine tiles are supplied but apparently they are unfilled... I haven't seen them yet. Given that I have only ever fitted 'filled' travertine I am somewhat daunted at the prospect of a large floor requiring a lot of multi size stone tiles which might all need filled before I can use them.. What do I fill them with? Can I just use grout? Its an electric UFH floor...
Thanks for your advice!
J Sid
After you have fitted ufh I would use Ditra uncoupling membrane then
Lay them as normal paying special attention to back buttering the stone and filling ALL voids. Some my come though to the face, don't worry, just wash off when laid
Once laid clean them and allow to dry completely.
Give one coat of sealer, allow to dry.
Grout, filling all joints and holes in tile, wash off.
Leave to dry for a copy of days and seal again. :)
This is an un-filled travertine floor, finished with bees wax and polished,
In Parliament Square.
If the client purchased it that way, why would you fill it? Most folks just let the grout stay in the voids.
It's the issue of adhesive seeping through the voids when pressed down - I use grey addy & it will be a contrast issue; cleaning the addy coming through would be a pita..
I've laid plenty of travertine; but every one was already filled, at first I thought it was a mistake but the tiles are definitely unfilled; presumably cheaper...
Certainly not cheaper, it's natural trav as opposed to the pressed crap.
U shouldn't be using grey addy with natural stone anyway, always white!!
Work clean, wash as u go, it's fine.
Dhtiling
463
Alaska
Never had an issue with the thinset coming through, but I guess a very bad stone could be open enough for that to happen. I would use white as said earlier, and if you have a grout color already chosen, You could color your thinset in case you are a little sloppy on clean up and if it comes through a little.
Rich Midge
598
Liverpool
This is all you need to know! I couldn't tell you how much trav I've laid, we were getting through pallets and pallets of it every month a few years back and it's always laid to the exact method as detailed above.
Reply to Unfilled Travertine? in the Australia Tiling Forum area at TilersForums.com
  • Sticky
  • Question
