Check me out!
Ian
I was feeling a bit brave today and decided to try out my new circular saw, I'm now a fully fledged multi trader!
Tomorrow I'm going to butcher a plinth 🙂
Cut the bottom bri and then run a 30mm bead of Silicon to cover up all the chipped plinth.
Depends on how much you're taking off the bottom of a plinth but I always use a planer and scribe them.
To save you the trouble of using clamps and spirit levels and subtracting measurements. There a simple jig you can make.
Get a piece of 6 mm ply of you desired length glue and pin a straight piece of lathe to it. Make sure the width of the ply is greater than your saw. Put saw fence against the lathe and cut straight through the ply. Now the next time you cut simply put the ply edge against your cut line with confidence it will cut it bang on. Pictures on request if ya fancy making one :thumbsup:
That's a great bit of advice, cheers.
I do the exact same as Bri has done in the photo.
I'm not a multi-trader though. [emoji1][emoji1]
Get a piece of 6 mm ply of you desired length glue and pin a straight piece of lathe to it. Make sure the width of the ply is greater than your saw for extra stability add draught excluder tape to bottom. Put saw fence against the lathe and cut straight through the ply. Now the next time you cut simply put the ply edge against your cut line with confidence it will cut it bang on. Pictures on request if ya fancy making one :thumbsup:
Ive got a festool plunge saw now but that set me back nearly 600 quid with the tracks but worth every penny. The system i described was how i used to do it. My festool is like the sigma or rubi of tile cutters :thumbsup:
Are you a chippy by trade david..?
One the best tools in my van !
i hardly ever use my planer anymore really. When im fitting doors this is the beast i use. Back bevel of 3 degrees job done. I ise a makita or freud blade for it works a treat
Why? Because you can't cut plinths! [emoji23]
I had to refit a toilet in my mates house the other day after tiling his floors, had to cut pipes use tighten up thingies to tighten up stuff and push stuff on , not one leak, I'm a bloody plumber now [emoji33][emoji106][emoji41]
Plumbings a doddle Craig, it's as easy as putting nuts in a monkeys mouth.. [emoji6]
Speaking of plumbing, I did a bit of that today as well. Used some solvent weld to fit an Impey drain. I'll be able to get a certificate soon :lol:
We make diamond blades that fit the TS55 Festool, we currently have three types that fit depending on what you're cutting.
Currently
Granite
Quartz
Porcelain/Ceramic
These were produced to request for a number of large customers we have to solve particular problems they were having cutting their materials.
Currently
Granite
Quartz
Porcelain/Ceramic
Will it void warranty on festool? As saw its designed to cut wood etc.
Check me out!
Ian,
Concrete guy,
Ian,
Concrete guy,
