corner pieces for 90 degree trim
Mike
do any of the trim manufacturers make a corner piece for 90 degree trim? it has to be 3 way. the reason i could do with it is for a tiled bath panel and i want to avoid the sharp corner if possible. i've never found the need for them before. cheers :thumbsup:
Something like this Mike in metal, I know its not rounded but it looks the biz
I thought you said L shape trim ? Confused now !
It is L shaped but I was wanting a corner piece that was slightly rounded so as not to have a Sharp point if you know what I mean. If I was go file the mitred point it would cause a hole
tapatalk on my HTC
I was wanting a rounded corner if possible, I can mutter the trim to look like that but its still quite Sharp
tapatalk on my HTC
These are a solid cube that slot into the trim, no mitre-ing just straight cuts, you might be able to file a rounded corner and then wet and dry and polish up
tapatalk on my HTC
I see what you mean now, and I've never seen anything for L-shaped trim only square or quadrant.
Thanks very much. I'll have a look at them corner pieces or it'll have to be a sharpish corner
tapatalk on my HTC
I get mine from STS in Leeds 0113 7818384. Speak to Martin
Mike,
John Benton,
Mike,
John Benton,
