Which mapei addy for basazza glass mosaics
P
peckers
Hi peeps, I have a job installing Basazza glass mosaics they are 10mm paper faced on a 300x300 sheet. the specs are to use mapei addy and Basazza are supplying there own grout.
I am tiling onto wedi board and it is in a wet room!
I havent used much mapei as its not that readily available down here so which addy would you reccomend?
thanks in advance...
Looks like P10 with the keraply additive as its got more body jets that you can shake a stick at and its got a waterfall in the wet area too!!! oh and the Basazza mosaics are being made especially with a persons head and face murial in it !!!
hi steve
adesilex p10 as neale mentioned but i have used keraquick white, with latex plus in the past and mapei have said that was adequate so its an alternative if you have and bags of keraquick in storage!
Nice job it shall be. the panel murial in the book is approx £5000, but as its being altered/changed to suit the customers requirements its gonna cost near the £8,000 mark for just one panel thats with out the rest off the walls :drool5:
So theres absoloutley no pressure in getting this absoloutley perfect :lol: none at all :mad2:
oh and I hate paper faced mosaics at the best off times :incazzato:
Now this is just the shower wall areas that is being done in this and the rest off the floors are in limestone with a big mixture of pebbles in the floor too!
This is going to be a long job as there is shapeing and bull nosing to be done..
This will be good for my portfolio :drool5:
That should be fun!
I take it you will be smoothing over the screw/washer plates in the wedi.
Better hope the joints are 100% flush!
That should be fun!
The joints will be flush as im installing the wedi and doing the prep myself! all screw and washers will be taped over using the wedi waterproof tape!
Sounds excellent and better than painting hey! Looking forward to another quality set of pics Steve :thumbsup:
peckers,
Scott,
peckers,
Scott,
