Weber powder addy info...
R
Rich
I keep putting up info on Mapei products, so I thought Id better be fair and put something up here for those of you that dont use Mapei...
Weber.set WF
Wall and floor adhesive
  • Standard setting (24 hours)
  • For fixing ceramic tiles and mosaics to walls and floors
  • Available in grey and white
  • Properties can be enhanced with Weber AD230 and Weber AD250
  • Supplied in 10 & 20 kg (white) 10 & 20kg (grey) bags
  • Coverage: 1.5kg of powder per m2 for every 1mm of bed thickness
Weber.set Plus
Wall and floor tile adhesive for low porosity tiles
  • For fixing ceramic and porcelain tiles to walls and floors
  • Polymer modified to provide a strong bond onto tiles/substrates with low porosity
  • Available in white
  • Supplied in 20kg (white) bags
Weber.set SPF
Flexible, wall & floor tile adhesive
  • Highly ploymer modified
  • For fixing ceramic and pocelain tiles to walls and floors
  • Will accommodate limited movement, from heated screeds and/or over boarded wooden floors
  • Supplied in 20kg (white) 20kg (grey) bags
Weber.set Rapid
Rapid strength tile adhesive
  • Rapid setting, grout in 2 hours
  • For fixing ceramic tiles to walls and floors
  • Specifically developed to allow easy bedding of large format tiles
  • Available in light grey and white
  • Supplied in 20kg (white) 10&20kg (light grey) bags
Weber.set Rapid Plus
Rapid strength tile adhesive for low porosity tiles
  • Polymer modified tp increase bond to tiles and substrates with low porosity
  • Supplied in 20kg (light grey) bags
Weber.set Rapid SPF
Flexible, rapid strength tile adhesive
  • Highly polymer modified
  • Will accommodate limited movement, from heated screeds, and/or over-boarded wooden floors
Weber.segt WF21
Highly flexible floor tile adhesive
  • Medium setting, grout in 5 hours
  • Accommodates movement and bonds to difficult surfaces
  • For fixing ceramic and porcelain to floors
  • Two component system
  • Available in grey
  • Supplied in 7kg with 3.75lt of liquid of 25kg with 13.5lt of liquid
  • Coverage: 0.8kg of powder perm2 for every 1mm of bed thickness
I have been using the webber tubbed gear this week and i thought it was excellent,but imo sontex acrylic has the best grip:thumbsup:
Re: Weber power addy info...
hi mate, ive used a few of these products recently in white and am pretty impressed good quality gear at a good price:thumbsup:
I used Weber for a couple of years many moons ago and cant say there is anything wrong with them, pretty good stuff, I just discovered the path to enlightenment that is Mapei :arabia:
Used it on my last bathroom job - good stuff and very cheap.
Their rapid set is mega rapid setting so great for skimming and bottom row of tiles.
Will definately use again.
You can add the AD250 undiluted into the weber.set plus and the weber.set rapid plus as well which is good because it gives you a two part adhesive but still a 20kg bag.
Think the AD230 is mainly for the grouts.
if your a weber fan
then give them a ring on 01525 722 127...they will send you out a 200 page glossy brochure called..'weber tiling soultions' its full of tiling scenarios and it covers every single one of their tiling products inc all tech spec....
i think weber external one coat renders are excellent but i much prefer mapei, for tiling products but i do use weber on ocassions and its ok imo........ps great thread dylante :0)..
ed
I like weber set plus for walls and the low dust for floors.
The levellers are very good as well.
Rich,
Stephen@Weber,
Rich,
Stephen@Weber,
