Bigger Tile Spacers (To re use ?)
sealtiler
Hi,
I am currently working with a tiler who has 21 years experience and is a total expert.
He has asked me to source re-usable tile spacers, which apparently are same thickness 1,2,3mm etc, however they are placed between tiles and can easily be removed afterwards as they have an increased depth for grip - this also prevents the spacers slipping behind tiles when using a larger notched trowel.
HOPE THIS MAKES SENSE ??????????????????????????????????????????????????????
Does anyone know where I can source these spacers ??????????????????????????????????
Thanks in a anticipation !!!
Sealtiler !😕
You can re-use any spacer. Just don't push them in all the way. If you're using crosses and you put them in the corners you'll have a hard time getting them out. I used to use crosses but used two at the bottom of every tile about 10mm in from each side and the odd one in the virtical joints where required.
The trick is to work in patches and as your adhesive grips or starts to go off, you can just keep pulling them out as you work your way around the wall or floor to re-use them.
There are spacer pegs and wedges too.
There are some foam ones available that you can leave in, that will accomodate expansion / movement. 🙂
He's been doin this for 21 years and wants to save a few pence on spacers........... beats me.
no offence mate but did he ask you to get a left handed screwdriver and a bubble for his level aswell
Been stood in Topps for 2 hours now,friend asked me if I would go in and ask for a longweight for him. lol
I'll see if they have any sky hooks for you mate,its no problem as there out the back fetching me a straight s hook.:wink_smile:
The spacers you are talking about are long leg spacers from Rubi, If you require any let me know and i will order some for you, they are about £4 per thousand, as Dan says any spacer should be long enough to get a grip of and put in and pull it out quite easy. The rubi ones are for the large format tiles you are talking about where the extra lenght and depth comes in handy
Spacers are designed to be lost.Not very environmentalty friendly that....never leave a spacer behind,if you you ask yourself... what is that spacer doing?stopping you from getting nice clean flush grouting line,costing me money replacing it,clutterinmg up my tool box,clagging up me hoover,trapping in my boots just because it's shaped like an X dosn't mean to say that you have to find an X space to put it in!!!!!!!!!!rest it on top of two tiles and re-use it plz,if sat on top then it cant be lost below THINK ONCE,THINK TWICE THINK SPACER
Hey Dan, any chance of changing Gaz's title to 'Spacers Rights Protester'?
yea lets respect them little kisses!!!
Added post information (due to double posting):
PS VAR,stop going on arcades bud!,it takes an hour to scroll past your posts LOL
At last after all the Micky taking I have now found what I was looking for and they are just the job.
Check out this site:
www.3dspacers.com
Let me know what you think !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Or if youve got nowt to do- just take the ****?:beer_yum::guy_handsacrossamer :coffee:
sealtiler vbmenu_register("postmenu_12778", true);
Professional Tiler
Rep:
Re: Bigger Tile Spacers (To re use ?)
www.3dspacers.com
__________________
SealTiler
I am surprised by your comment calling many of us 'low level tilers' . Just because you have been on a good course and are working out of a good shop DOES NOT make you a tiler after a few months. Many people on here have been tiling for a long long time and know their job inside out. As with many trades it takes years of experience to become an expert in the line of work you choose. I speak for myself and probably others here too who have many many clients on their books that simply wouldn't dream of employing anyone branded low level. I am all for people learning the game and encourage it greatly but walk before you run. Most of us were only having a bit of fun which there is nothing wrong with. If you were offended then apologies to you, youre just lucky leatherface wasn't here as he takes no prisoners:devil_smile:
Hmmm, wouldn't like to stand on one and need another bucket just for spacers.
But could practise golf with them, should go pretty straight!
www.3dspacers.com
yes they wont be as easy to lose ,finally the spacer fights back,sympathy to the spacer league
Bit too much of a gadget if you ask me, i think it would take to long to turn the thing arround to find out which side you are putting it in, never seen anything like it before, how many sides are there to it. Let us know how you get on with them when in use, if your passing the training centre drop one in and lets have a look at it.
Darren
sealtiler,
DHTiling,
sealtiler,
DHTiling,
