Discuss What tile adhesive is used for large format tiles? in the UK Tiling Forum area at TilersForums.com.
The best adhesive i have found is PCI nanolite can go up to 15mm PCI Nanolight®
not for me lolSo can Keraflex maxi and it is a damn site cheaper..:smilewinkgrin:
Could it be that the primer is not penetrating into the plaster so sticking large format tile to thin layer of primer that will have a weak bond and adhesive pulls off primer?
the first thing here is large format need an adhesive with out to much resistance not to much sand an adhesive you can add a little more water to not one set in stone that can blame you later next the trowel you use is just as inportant .some times the old know better than the new .Has adhesive rexommendations changed now we're 5 years on?!
Reply to What tile adhesive is used for large format tiles? in the UK Tiling Forum area at TilersForums.com
