Discuss Tiling on water resistant chipboard in the Australia Tiling Forum area at TilersForums.com.
AliGage
Subscribed
I had to remove the plywood as floor was too high, or would have been. This was cemented and screwed to the chipboard and was a lot of fun to remove !!!!
It's only you said the 9mm ply was cemented and screwed.
Have you managed to clean up the floor ok then?
The quickmat decouplers need a flat clean surface before fitting.
I still think you need to overboard the chipboard. Which raises you 6mm plus addy. I'm struggling to see how there is a concern over a big step up from the carpet. Underlay and carpet is what? 12mm.
So overboarding with a backer, addy, plus tile would create a step, worse case 8mm?
Reply to Tiling on water resistant chipboard in the Australia Tiling Forum area at TilersForums.com
  • Sticky
Hi, Can't seem to find a solid answer as I realise so much depends on multiple factors. I'm...
