I would like to put tiles cutting into the original floorboards where the the 2 different flooring meets. I’ve generally seen it with engineered or hardwood flooring but not old floorboards.
Is there a way to avoid cracking tiles?
Something like this?
However these are wood effect porcelain tiles.
If you get the wood correctly fixed then put a flexible joint to where they meet it should be fine.
Good luck and enjoy.
Thank you.
Yes, I’ve seen many examples but none on actual floorboards so I thought I’d check.
So if understand correctly as long as there’s flexibility on what they’re going on so they can move with the rest of the boards it should work.
Cheers
Hey all
I have just found out that Chris Emery from Schlüter-Systems Ltd will be at Tileflair in Reading on Wednesday 15th May for a Q&A session!
So if you are in the area see if you can pop...
Created a new forum category for Tilers' Talk covering all other countries. Please start a new thread of your own by clicking THIS LINK. (you need to be logged in to post)
I'm looking for a few Porcelanosa Town White Polish / Pulido floor tiles - badly laid in my new build and a few have cracked. One or two would be useful, I could use up to 8 to allow for some wastage.
I have moved into a new house and want to tile the downstairs bathroom walls. Its not a big room but my wife likes the idea of a feature wall tile and then a grey / white tile on the other 3...
Another First for UK Tiling Forum; Crossing the 1 Million Posts Mark Soon
It appears the other UK Tiling Forum is using a Free WordPress (that’s fine) but they went for wpForo instead of bridging...
