Guest viewing is limited
Slate tiles onto screeded floor with wet UFH
pm.services
Can anyone help with the following.
I intend to buy 85sqm of 800 x 400 10/12mm thick brazilian slate tiles to be laid onto a screed floor that has wet UFH installed. 20 sqm of the above is to laid outside to form a patio.
We have had a set of sliding doors fitted and the threshold is now 15mm higher than we originally planned we are now at 35mm. We were hoping to create a seamless transition from inside to out.
Can we lay the slates on a sand a cement bed if not has anyone any suggestion on how we can lay the slates.
Hi,
I done a job at chistmas time with Brazilian slate. There was a big dip in the centre of the floor and I was able to build up the bed in the middle part of the floor with rapid adhesive.
I wouldn't think you would have any probs building up your extra 15mm like this (although the draw back is using more adhesive).
Alternatively, you could use a self level compound to build up the floor level (self level compound not cheap - you could do half self level n half bed build). Look on the bright side at least you should have a lovely flat floor when it's done.
Good luck
Charlie:8:
UK Tiling Forum; UK
pm.services,
palmers_tiling,
pm.services,
palmers_tiling,
