Preparation for Mosaics on floor
Hi all,
After some advice. I’m tiling a 4m floor in 1 inch hexagon mosaics. The floor is green chipboard which is pretty secure but I would always use ditramat 25 on it prior to fixing but Schlüter have said not to fix anything under 50mm on to ditra 25. Anyone had the same issue? It’s not the sort of job I fancy doing twice!
Cheers for any help.
As above overboard with something like hardie backer but you may want to skim it over with a smoothing compound after to get it perfectly smooth to recieve mosaics
Hardie Backer flies and screwed and then go over with a feather edge smoothing compound to fill any little gaps such as screw heads etc
Definitely wouldn't recommend orbry, wedi, marmox etc for small mosaics. Point loading would be too much and the board could compress.
Result would be a mess.
JaydoubleU,
Tile Fix Direct,
JaydoubleU,
Tile Fix Direct,
